Sunday Afternoon plus alternate Sharpie video
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › Basic Techniques and Sharpening Strategies › Sunday Afternoon plus alternate Sharpie video
- This topic has 12 replies, 8 voices, and was last updated 06/30/2020 at 1:37 pm by
Richard.
05/18/2020 at 5:26 pm #54258
No offense to anyone but our forum has become less of what it once was. So in an attempt to encourage conversation here is how I spent my Corona Sunday afternoon:
I did my son’s 8 Shun/Henckel kitchen knives this weekend. They have never seen the WEPS. I am a 3+ year WEPS user and feel I have gotten pretty good at it. 100 grit thru films and light stropping (14 total). My end test is scalloping shiny magazine paper. A few things I learned are:
1. Fine tune your blade placement in the clamp by focusing on the curve and putting your thumb/o-ring on the rod (without a stone and without the AAG as it is in the way), and gently putting your thumb/o-ring against the blade, rotate the rod to watch how close your thumb/o-ring (fixed point) follows the knife curve. Its a little 2 hand tricky (the knife needs to be moved iteratively to find the sweet spot) but it does a good job honoring the geometry prospects of the WEPS vs. a factory bevel. Once the sweet spot is found I clamp the knife and the put on the AAG & key. I then document the location (I may slightly reorientate the blade to rest on the key and be centered in an AAG square). I double check the thumb/o-ring curve thing and move on. I no longer use the sharpie. It sounds like alot of back and forth but it really isn’t. I can make a video if someone wants.
2. Tape every knife to avoid those pesky surface scratches. I got one and I swear I have no idea how. Very disheartening to see one next to a mirror bevel. Pretty impossible to remove.
3. Clean your 100 grit stone which puts your burr on. I need to use it 20x longer than the other grits and I thought I was wearing it out til I cleaned it with a toothbrush and Bar Keepers Friend. The timing of the first burr varies alot with steel, angle and damage, I was running 10 mins doing 100 grit alternate side med-hard scrubbing strokes.
4. After the first burr creation I switched from counting strokes to timing strokes (phone stop watch). Just quick glances to the clock allows me to focus on consistent strokes more. After the first burr, I spent 30 seconds total doing alternate side edge trailing strokes focusing totally on smooth consistent full strokes listening to the sound instead on counting. Of course the number of strokes will vary a bit with knife length but I was getting about 25 strokes per side in 30 seconds. I then move right on to the next grit as there are 14 total including the 100. I also ONLY edge trailing heel to tip strokes for safety sake (except for 1 edge leading stroke to remove the 100 grit burr with the 200 grit stone and the 100 grit scrubbing). I do not need to take scallops out of my fingers and consistency matters.
5. I realized that the top and bottom of the diamond plates are rarely used as most of the abrasive action is in the center ¾ of the stone. I use the ends to smooth out any microchips / slight damage before raising my first 100 grit burr (scope needed). Worse damage needs a file or grinder but be careful not to put unintentional dips in the edge. I think this improves the process/final edge in lieu of depending on the 14 grits to “eventually” reach the bottom of a microchip. I was amazed at how many microchips were present on a well-used kitchen knife.
Note: I used my scope to double check all of this and am fully aware that there are many ways to skin a cat.
I would like to hear other hints from the rest of you.-
This topic was modified 4 years, 11 months ago by
Readheads.
Readheads.
05/18/2020 at 5:32 pm #5426205/18/2020 at 6:40 pm #54266It might take me a while but in the meantime you can read thru this:
https://knife.wickededgeusa.com/forums/topic/geometry-and-kinematics-of-guided-rod-sharpeners/
The guy who wrote the analysis is one of the real smart ones (unlike me). LOL
05/21/2020 at 4:04 pm #54302I made a quick video of the alternate method of finding the correct blade placement in the WEPS clamp to honor the OEM knife curve bevel to the tip. I find it much faster although it is a 2 hand kind of thing. Placement is important for a knifes first time in the WEPS clamp then if you document the location with the AAG and key, you never have to mess with the sharpie again for a specific knife. I had to use a link for the video, hopefully it works.
Thanks to Airscapes for the indicator (although I usually just use my thumb).
https://photos.app.goo.gl/s4pG4dXA6919UoMv9
05/21/2020 at 5:00 pm #54307Your welcome, but not sure what you are referring to.. video won’t play for me.
05/21/2020 at 7:38 pm #54308Thank you for the video, it is helping. This is very similar to the way Mr. Curry shows in his video.
05/21/2020 at 8:14 pm #54309It should play, its just a link to a shared Google photo/video thing. It has your rod stop thing that you gave me. Did you see my post about “Touch Up”. I had you in mind for a prototype on 3d print.
05/21/2020 at 8:53 pm #54310It should play, its just a link to a shared Google photo/video thing.
This is what I get when I play it.
05/21/2020 at 9:13 pm #54313It played for me.
05/21/2020 at 10:52 pm #54314Send me an email to tmorganjets at gmail.com
06/17/2020 at 12:14 pm #54381Can you please tell me how you made the indicator you used in the video?
06/17/2020 at 12:36 pm #54382You can buy the indicators, (they’re called “stone stops”) from forum member “airscapes”. Just click his screen name, in blue, a few posts up in this thread to private message him.
Here’s a link to custom accessories available for Wicked Edge users.
Welcome to the forum Andrew.
06/30/2020 at 1:37 pm #54447Kinda goes hand in hand with the pinned “How to Find the Sweet Spot” post.
