Need Angle of 45 Degrees
Recent Forums Main Forum Techniques and Sharpening Strategies Need Angle of 45 Degrees
Viewing 15 posts - 1 through 15 (of 43 total)
  • #56394
    Mike
    A buddy asked if I could sharpen his planer blades that require a 45 degree angle and I said I would give it a go. I have the WE130 and the largest angle is approximately 38 degrees.
    Looking to see if there is any “tricks” or modifications that can help get the required angle. Looking at possibly an extension on the bottom rod that the guides rods slide on to extend it out further to get to 45 degrees.
    Thought I would toss this out to the experts for some opinions
    Thanks
    Mike
    #56395
    000Robert
    • Topics: 7
    A buddy asked if I could sharpen his planer blades that require a 45 degree angle and I said I would give it a go. I have the WE130 and the largest angle is approximately 38 degrees. Looking to see if there is any “tricks” or modifications that can help get the required angle. Looking at possibly an extension on the bottom rod that the guides rods slide on to extend it out further to get to 45 degrees. Thought I would toss this out to the experts for some opinions Thanks Mike
    You probably need the chisel adapter. They say that it will handle planer blades up to four inches wide.
    #56397
    Mike
    Thanks – not sure I want to make a huge investment and also not sure it would get me to 45 degrees. I do have the scissor attachment and it was not close enough
    mj
    #56398
    000Robert
    • Topics: 7
    The scissor attachment is made for scissors, not planer blades. I’m sure that the chisel attachment could accommodate a 45° angle. It is made to use for sharpening chisels and planer blades.
    #56399
    Mike
    The scissor attachment did hold the blade correctly and am well aware of its intended use. Just thought I would try it to see if the desired angle could be reached
    #56400
    000Robert
    • Topics: 7
    I’ll let you know for sure in a few days when my chisel attachment gets here.
    #56401
    Mike
    Thanks – it would be a hefty investment if I am only doing a few – will be good to know
    Mike
    #56402
    000Robert
    • Topics: 7
    Thanks – it would be a hefty investment if I am only doing a few – will be good to know Mike
    Well you know what they say: better to have it and not need it than need it and not have it. I really don’t use chisels, gouges, and planers much but my son does. He loves woodworking. I love working with steel. So I bought the chisel attachment mainly for sharpening stuff for him. I also need to get a grinder with a CBN wheel to sharpen some of the gouges. I’ve also been thinking about getting a decent belt grinder.
    #56410
    000Robert
    • Topics: 7
    Hi Mike. My Chisel Attachment came in today. It looks good and is solidly built! I’m not the worlds greatest at geometry, but it seems to me that the average user can get to about 50°. So 45° should be no problem. That’s with the screw in the most inside hole and the guide rod adjuster screwed all the way in, and the chisel set to the stop plate like it shows in the instructions.
    I used the holes in the guide bar because not everyone has Ed’s (NotSharpEnuff) micro-adjusters. With my micro-adjusters I can go to about 53° or so.
    The chisel installed into the CA sits at 26° from the base level.
    #56411
    Mike
    Thanks – good to know. If I get more requests to do them I will explore that option. Appreciate you getting back to me
    #56412
    000Robert
    • Topics: 7
    You’re welcome.
    #56414
    Sorry I hadn’t read this before, as I could have saved you some time and money.  Planer blades wouldn’t work in a chisel adapter or even in the WE because of their angle.  You can, however, use the diamond stones to finish the edges.
    Planer blades tend to see damage that is quite deep along their edges and which usually requires some sort of powered sanding to remove enough steel to eliminate the edge damage.  Hitting a staple or other really hard component will do some nasty damage.  Most pro woodworkers will always check for metal in the wood with a metal detect first.
    I made a fixture to hold 2 blades at the correct angle out of a piece of 2X4 similar to the one shown here.  You can use a table saw set at 45 deg. to make the slots for the blades.  Most saw blades are 1/8″ thick and and the kerf will fit the blades from my Dewalt planer perfectly. I added some screws to lock the blades in position.  You can work the edges with a oil or whetstone, but I hold the fixture upside down on a belt sander – provided it has a flat backer platen.  Using 220-grit belts, I can remove the dings and chips fairly easily.  Using stones as shown in the link will take forever to accomplish the same results.  You can, however, use your diamond stones to finish and polish the edges.
    If I didn’t have the equipment, I’d send the blades out for sharpening.  Any woodworker store would or should have some resource available to sharpen blades.
    #56415
    Mike, are you talking about a hand block planer or a larger power planer used on lumber?
    #56416
    000Robert
    • Topics: 7
    Yeah, I was using a chisel and assumed that a planer blade would be the same. But I don’t have a planer blade to try. I don’t do woodworking except to install a new door lock or something.
    #56417
    Mike
    Power planer – 2 blades that spin and run live edge lumber over them
