WEPS Low Angle Adapter or Tormek Jig?
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › Basic Techniques and Sharpening Strategies › WEPS Low Angle Adapter or Tormek Jig?
- This topic has 30 replies, 9 voices, and was last updated 03/21/2015 at 9:46 pm by
tcmeyer.
02/26/2015 at 9:05 pm #23901
For those of you who have them………does the Tormek accomplish the same lower angle the Low Angle Adapter does?
02/26/2015 at 9:23 pm #23902Josh has the Tormek jig mounted in the LAA. Crazy low angle!
Wicked Edge (WEPS) at the lowest possible angle:
02/26/2015 at 9:39 pm #23903Josh has the Tormek jig mounted in the LAA. Crazy low angle!
http://youtu.be/rkMAo2eztpY%5B/quote%5DYea…..I’ve seen that. I was wondering……one or the other.
02/26/2015 at 10:13 pm #23904Well ups finally delivered my canceled order of both. And my reorder of both……. so now I have 2 of each.
02/26/2015 at 10:33 pm #23905Josh is using the Tormek SVM-00, which is technically a ‘small knife holder’ The longer the blade, the trickier that guy is for low angles because more and more flex get’s introduced because you’re holding it by the handle (true whether using it on either Tormek or WE). So that jig has it’s limitations.
Ideally you’d want both, but the WE LAA would come first, then pick up the Tormek.
02/26/2015 at 10:48 pm #23906and…
The Tormek jig is trickier to clamp up the knife. The Tormek jig can definitely get much better angles.
The Tormek jig is not meant for longer blades as the flex introduced will compound (handle design, clamping pressure, blade length, blade flexibility)
It has it’s place though, just secondary to the LAA, imo.
02/27/2015 at 11:08 am #23908While the tomek is technically a small knife holder, I have used mine for a spyderco endura and a para 2 with excellent results in part because there is no issue of dealing with the issues of clamping a FFG while attempting a low angle.
What I did is make a vertical mark on the top clamp of the tormek, then align the blade to it. Easy & repeatable. B)
What Montana says is also true, the tormek does “flex” around a bit and I find myself sharpening 1 handed(especially the tip are).
Also I believe the flex could be greatly reduced simple by replacing the current straight bar with something a little stiffer. Easy mod.
Finally I think the #1 thing(besides low angles) that sold me on this arrangement(LAA + Tormek), with longer rods, is that the ARC is larger….This means a larger sweet spot matching the blade profile better and allowing for a uniform edge bevel… :huh:
02/27/2015 at 9:59 pm #23921It is nice to know about other variables when used as a combination.
Could someone answer OP’s original question first?
I am also interested as pertain to individual stand alone use comparison!
TIA!
02/27/2015 at 10:28 pm #23924Well, he asked two questions on two separate posts and both were answered., and the post title was considered too.
Q. “For those of you who have them………does the Tormek accomplish the same lower angle the Low Angle Adapter does?”
Answered “The Tormek jig can definitely get much better angles.”Q. “I was wondering……one or the other.”
Answered “Ideally you’d want both, but the WE LAA would come first, then pick up the Tormek.It is not really a yes/no answer, thus the wandering detailed answers.
If someone is trying to pick between one of these tools to add to their toolbox, you can’t just say the Tormek jig gets lower angles and leave it at that, because the Tormek jig has limitations that make it impractical to try to use it for a super low angle on the WE or the Tormek. For instance, an average sized thin flexible fillet knife would be miserable using the Tormek small knife jig.
So, we get the wordy answers trying to help a guy get the big picture… and sometimes the answer gets buried in the mix.
Speaking of wordy: the answer to the original question is “the Tormek jig can definitely get much better angles” (than the LAA) and that hasn’t changed.
apples and oranges though.
02/27/2015 at 10:43 pm #23926and in case what you are saying is that you want someone to compare the systems:
the Tormek small knife jig used on the Tormek
against
the LAA used on the WE:The Tormek small knife jig used on a Tormek will win for low angle capability.
Won’t be as refined an edge as a WE edge.
02/27/2015 at 11:31 pm #23927I am having problem opening your underlined comparisons.
And appreciated you taking the time for the replies!
02/27/2015 at 11:38 pm #23928Sorry about that… here you go with no underlines. Let me know if I am on the right track with what you’re asking.
against
02/27/2015 at 11:41 pm #23929and in case what you are saying is that you want someone to compare the systems:
against the LAA used on the WE:The Tormek small knife jig used on a Tormek will win for low angle capability.
It seems to me like what people are wanting to know is what can get lower angles when used w/ the Wicked Edge, the tormek jig or the LAA. I personally have not tested them side by side, but I agree with you that the Tormek jig does have its limitations w/ longer bladed knives. It is more of a solution for smaller bladed knives say 4″ or less. The LAA also has limitations if you are wanting to do small pocket knives w/ thin blades, like the SAK. you also can only put the knife to the limited depth, nothing like the original vise. so tilting the knife in the LAA is pretty much out of the question.
So my answer would be to ask what kind of knives will they be needing to use this on? then we can give the best advise
02/28/2015 at 12:14 am #23934It seems to me like what people are wanting to know is what can get lower angles when used w/ the Wicked Edge, the tormek jig or the LAA
That’s how I took it too.
Bravo!
02/28/2015 at 12:24 am #23936I bought the Tormek not really interested on how acute an angle I can get but rather, using it for small knives. Especially for a few with FFGs and a few shorter than 3″ lg x 3/4″ blade width.
Since OP’s question also pertains to me, it is also good for me to have the resource and understand the limitations from experts here on the forum.
TIA!
