Diamond Stones shaped for convex edges
Recent Forums Main Forum Product Announcements Diamond Stones shaped for convex edges
Viewing 15 posts - 1 through 15 (of 21 total)
  • #46274
    Alan Yip Choy
    • Topics: 4
    Is it possible to make diamond stones that are shallow curved along their length in order to handle convex edges?
    #46275
    #46278
    David
    On my browser the URL didn’t parse correctly, let’s see if this is more click-friendly for Alan:
    https://wickededgeusa.com/collections/sharpening-stones/products/medium-400-grit-fine-600-grit-stones-for-curved-blades-1
    But note his question was about diamond stones; and with all the forum posts I’ve read about folks who have become disenchanted with their ceramics I wonder the same thing.
    #46279
    Alan Yip Choy
    • Topics: 4
    Hi Folks,
    I was not clear enough. I meant that the stones would actually be curved in a very slight C curve not cross sectionally (SP?) as the ceramics that you sent me the link for (I have a pair of these already). Sort of like the brackets that I used in this post.
    Thanks again for your replies.
    #46280
    Ah, I see what you’re getting at. You’re thinking of having the plates with a slight radius across the length of the cutting surface to intentionally put a convex edge on the blade. I imagine that it would be possible, but given that you can get a convex edge by making several facets and then blending them with strops without any extra tools, I don’t know if there would be much of a market for that idea.
    #46281
    These curved ceramics are of a much coarser grit as compared to the flat polishing micro-fine and ultra-fine ceramics that have a very long break-in period before you realize their benefits.  The coarser curved ceramics did seem to work well for me right out-of-the-box. They exhibited a scratched pattern very similar to my comparable grit whetstones.
    #46282
    Plus, we’re working on something else right now to address convex edges in a really neat way. It’s still very much under development, but the proof of concept works great.
    #46283
    Keep us posted when you’re ready to break the news!
    #46289
    David
    …you can get a convex edge by making several facets and then blending them with strops..
    I’d love some detailed instructions/guidance on this. Does this entail rotating the stones from the plane of the blade?
    #46290
    The process has been described several times on the forum and the knowledge base has good article on the topic as well. Here’s a recent thread on convex edges.
    #46421
    Peter Lai
    I thought KME has a curved rod specifically for convex edge sharpening.  Clay, is this the route your design team thinking or something even more elegant?
    #46430
    The curved stone face (or curved rods) seems like a really interesting approach, but I wonder how you’d actually make it work.  For instance, if the stones had a concave face and if you used diagonal down-strokes from tip to heel, the tip end of the edge would have a lower angle than the heel end.  Switching to heel-to-tip diagonal strokes would theoretically result in two bevel facets at each end of the blade, with a section in the middle which would have a single more-or-less average facet angle.  To achieve a uniform convex profile, you’d have to hone every point along the edge with every point along the face of the stone.  Not unworkable, but I think it would demand quite a bit of focus and repeated inspections on the part of the user.
    What do you think guys?  Am I over-analyzing this?
    The videos I posted of the two convex edges were a bit disappointing in terms of quality, but I had hoped for some commentary so that we could discuss other options and methods.  Also, I didn’t make a big deal out of it, but by making a number of smaller angle incremental changes, the facets seem to blend together beautifully, making the use of strops unnecessary.
    #46438
    NickedEdge
    • Topics: 9
    The blended bevel reminds me of digital audio, when you have enough frequency sampling points it begins to result in a near analog recording…
    #46439
    Mikedoh
    Ive always looked at digital/analog as particle/wave duality.
    #49292
    Mr.Wizard
    • Topics: 6
    There is a (conceptually) simple solution to this: make a plate with a subtle undulating ripple along its long axis.  This will give a continuously changing angle that combined with moderately different strokes should produce a convex edge in a nicely controlled range.
    Rough calculation indicates that with one ripple (up/down) per inch you only need about 0.55mm peak-to-trough to give 10° of variation.
    • This reply was modified 6 years, 2 months ago by Mr.Wizard.
