Bent vice
Recent › Forums › Main Forum › Sharpener and Accessory Maintenance › Bent vice
- This topic has 44 replies, 14 voices, and was last updated 05/12/2015 at 1:27 am by
JS.
01/22/2015 at 8:58 pm #22821
Tell me guys. Is my vice bent at the top or are all of them like this? Looks bent out to me. This is tightened all the way up. Bottom and middle of vice are touching….the top does not touch.
Attachments:01/22/2015 at 11:03 pm #22822Looks like it could be starting to bend on you. My original vise shows just a touch of light through the top (similar to your pic) after years of use and is working fine like that so I’d probably just keep an eye on it and if it gets wider give Wicked Edge a call and I’m sure that they will get you set up with a replacement lickety split
01/23/2015 at 5:59 am #22824Yeah its bent… I’ve had a few like this… Call wicked edge and they will get you a new one right out
01/23/2015 at 7:08 am #22827A few? How many WEPS does one man need?
01/23/2015 at 7:15 am #22828Some of us have a tendency to perhaps overtighten a bit? I was using a hex nut driver and it was supplying way more torque then was healthy for my first vice.
It’s a tough delima. I can be aggressive in my sharpening and prefer a rock solid knife mount, but too tight and the vice “no can handle”.
01/23/2015 at 7:27 am #22829Maybe it is just me, but I cannot see how that slight variation can make hardly a difference when mounting the knife. Can you actually tell that the knives are not holding as well as they should be because of this? Are they bending to one side (assuming not FFG)?
01/23/2015 at 7:58 am #22836Some of us have a tendency to perhaps overtighten a bit? I was using a hex nut driver and it was supplying way more torque then was healthy for my first vice.
that is me… I like it to be rock solid and I currently “compromise” with a lighter grip until I can get my new tool steel vise heat treated.
Yes, they will create inconsistency. While this little of bending may not make that much of a noticeable difference, you really begin to notice it when doing knives with a small blade that you don’t have much area to clamp on to and you need a solid grip. And on ffg knives it will cause them to rock left to right.
01/23/2015 at 11:21 am #22839An opportunity to teach… For blades which can be clamped on parallel surfaces, before tightening the blade in the vise, you should set the two screws like so:
1. Adjust the top screw to set the opening between the jaws to a distance very close to the blade thickness.
2. Then set the lower screw to put the space between the two jaws at the bottom to approximately the same opening. Remember that it can only push – it can’t pull.
3. Now use the top screw to clamp the blade into the position you need. You only need to tighten the top screw enough to keep the blade from falling out of the vise.
4. Turn the lower screw until it make contact with the opposite jaw. Then turn the lower screw another 1/4 to 1/2 turn past contact.
Except for very heavy or very long blades, you should never need more torque applied to the lower screw than it takes to turn the 1/4 to 1/2 turn.
The upper screw shouldn’t need to be tightened more than snug. It is intended only to set the jaw opening distance.
Full-flat ground blades require more finesse. Check out Josh’s video at https://knife.wickededgeusa.com/forum/6-techniques-and-sharpening-strategies/13084-bevel-angles#18509
01/23/2015 at 8:40 pm #22845My vice looks pretty much the same
As Josh previously stated, it will definitely cause some inconsistencies.
The new vise Clay’s been working on should do away with the issue… When it will be available to buy, that I don’t know.
01/23/2015 at 11:02 pm #22848Mine looks like too and I just received it.
01/26/2015 at 1:42 am #22889Thanks guys. Sent Kyle an email with pics. Guess he will get back to me tomorrow.
01/29/2015 at 6:11 pm #22972I looked at mine last night, and when I press the bottom and middle of the blocks together there is a slight gap at the top like this. Can’t really tell if it’s bent though and not sure that it really affects performance…
02/09/2015 at 4:49 am #23195Sent email about my vise being bent. I received a reply within two days asking for my address and that they would ship me a new one. I have never had any company reply with this type of customer service. I sent my address and pictures of my vice and received the new vice within a week. This is one of the best companies I have ever dealt with as far as customers service.
02/09/2015 at 9:55 pm #23216Here’s my vise. Please watch and tell me what you think.
Thanks!!!
Wicked Edge Sharpener – Bent Vise: http://youtu.be/XJDr_txj6xs
02/10/2015 at 2:18 am #23224Just got off the phone with Wicked Edge and getting a new vise sent to me was way too easy. Awesome customer service.
THANK YOU SARAH!!!
