Using an ultrasonic cleaner clean stones
Recent Forums Main Forum Sharpener and Accessory Maintenance Using an ultrasonic cleaner clean stones
  • #55855
    mrjoker
    I have used my ultrasonic cleaner a couple of times to clean my stones and it seems to work remarkable well. I recently read a comment online (outside of this forum)  and they claimed that the manual stated not to do that.  However, I have looked my manual over from front to back and cannot find that anywhere.    Does anyone know of any reasons not to use ultrasonic?  Thanks in advance
    #55857
    airscapes
    • Topics: 20
    The plates are attached with Foam mounting tape.. Not sure if what you are cleaning them with could cause the adhesive to fail but if just soap and water which is the suggested manner of cleaning provided by WE you are probably ok.
    #55858
    I’ve never tried the ultrasonic route but do remember someone stating that there was a solvent used in ultrasonic cleaners that degraded the mounting tape.  Should be a non-issue if you use soap and water.  I keep a spritzer of alcohol handy to clean diamond lapping film and have found that it works great on the diamond stones too.  A little agitation with a finger tip is all that’s needed.  I have also read here that it works good for cleaning strops.
    #55861
    000Robert
    • Topics: 7
    I don’t see what is so difficult about using warm water, dish soap, and a scrub brush. I also use round brushes to clean the guide rod holes out with. Piece of cake. It is a lot easier for me to clean them the prescribed way than to use my UC.
    #55881
    mrjoker
    Thank you all for your replies.  I inquired with  Wicked Edge and they stated that they didn’t think there would be a problem using an ultrasonic cleaner and they have not ran into any issues thus far. To be transparent, they also told me to watch the adhesive on the stones for any breakdown and to let them know if I notice any.   As mentioned, I have used it a couple of times without any issues and without any solvent. If I do run into any issues in the future, I will be sure to post.
    Thanks to all,
