Puma White Hunter help
  • #29300
    Todd Heiskell
    • Topics: 5
    Has anyone tried sharpening a white hunter one the WEP. I have one on the way and was worried about all of the irregular angles on the blade. It doesn’t look like there is anywhere to clamp the blade except at the base. I was thinking about trying the tormek small knife jig and clamping using the handle. the other thing that worries me, is the angle of the edge. Im not sure it is the same all the way down the blade.
    #29301
    developer (ChrisB)
    • Topics: 53
    i have had good results with the Tormek SVM-00 small knife jig.
    #29302
    Looks to me that the knife may be to big for the Tormek adapter, but maybe not. Of the photos I see on the Puma web site, it looks like there is a flat area just above the belly, which is where I’d try first. Maybe even mount the knife so that it points upward at some angle to find a sweet spot.
    Do you have a Gen 3 vise? The blade is 0.2″ thick.
    Maybe use the Tormek adapter with one of the Ram units to stabilize the blade.
    #29303
    Todd Heiskell
    • Topics: 5
    I have the Gen II pro and my Gen 3 should be here Wednesday. I did consider the flat above the belly of the knife. Its been a few years since I have seen the WH in person but for some reason I was thinking that area was also sloped award the spine on the knife. That may be the way to go. the blade thickness might cause problems for the Gen III but I don’t think I would have any trouble in my other one.. I am beginning to think this would be a good knife for Clay to do a video on. Lots of things make this a bugger to sharpen
    #29308
    large knives like that w/ a grind on the spine can be problematic… sounds like Tom is spot on! that’s what I’d try…
    #29309
    Todd Heiskell
    • Topics: 5
    Well I received my White Hunter today. Tom you were correct, The flat above the curve is the best place. Thanks for the help!
