Hindered half track spanto grind questions
Recent Forums Main Forum Techniques and Sharpening Strategies Tips for Specific Knife Grinds and Styles Hindered half track spanto grind questions
  • #53620
    45srbest
    • Topics: 5
    The spanto grind on the half track doesn’t look like it needs to be handled in two different areas of the blade. It looks like it can be done in one continuous sweep (like more or less normal blades). Just wondering if anyone has done one of these and if so what position on WE did you use.
    #53623
    NotSharpEnuff
    45srbest,
    Personally, I would sharpen in two separate areas.  The drop at the tip versus the flat portion of the blade is pretty significant.  It’s not that the edge will be less sharp but the width of the bevel will be different.  If aesthetics of the bevel aren’t a concern, then sharpening with the single stroke will work fine.
    P.S. I’m definitely not an edge snob.  Sharp is sharp and that is my ultimate goal.
    Ed K.
    #53624
    jabas2000
    I did this knive in 2 steps.
    The recurve 21 degrees pro site, and the tip at 26 degrees pro site.
    #53626
    • Topics: 90
    I’d try this method as a positioning exercise to help you decide for yourself:
    I’d clamp the knife as high up in the vise as you can securely clamp it.  Then with the blade portions where the flatter rear portion transitions to the forward curved portion of the blade centered in the vise middle.  Then paint the bevel with your marker.
    With a wide angle setting on the guide rods, maybe 25 dps, I use a very fine grit stone like 1000 grit and use a light pressure and gentle edge trailing stroke, (i.e., up and off the knife edge).  Then examine the bevel visually to see how well the marker ink is removed from the apex.  Rotate the knife’s clamped position around the knife’s center point to raise or lower the handle relative to the knife tip, and/or  you may need to move the clamped knife very slightly forward or backward in the jaws.  Do this test only making one slight or small positioning change per test.
    Reapply the marker and re-examine the ink removal between each test.  Always using only very light pressure edge trailing stone work.  Your only trying to determine how well the stones matches the knife edge along the entire knife’s length by how it removes the ink.  (Your not trying to remove steel or yo sharpen the knife at this point.)
    You should easily be able to determine visually by the ink removal if you can find the best position to clamp the knife.  If you can’t find that “sweet spot” position, where the stone matches the entire knife edge, then you know you have to sharpen it in two separate portions.
    Be sure to record the sharpening position you find that works best.
    Hint: Start with clamping the knife so that an imaginary line between the knife edge heel and the knife edge tip, is positioned parallel to the jawline.  Then when you move the knife, move it in a direction to place the apex where the ink was previously removed, by your last trial.  If the ink is removed lower then the apex, then the apex needs to lowered to that place where the ink was just removed.  If on one end of the edge there’s barely any ink removal and the other end of the blade sees a wide area of ink removal then the portion barely touched needs to be rotated up and the wide remove portion rotated down in the clamp.
    #53627
    Brewbear
    • Topics: 7
    Thank you for the tips @MarcH, they are helpful indeed.
    #53628
    45srbest
    • Topics: 5
    I’m going to try what you said Marc. Should be interesting. I just have to put my wide blade clamp in and give it a shot. Gives me something to do on what looks like a rainy Monday coming up.
