Chosera Vs Ceramic Stones?
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › Basic Techniques and Sharpening Strategies › Chosera Vs Ceramic Stones?
- This topic has 50 replies, 10 voices, and was last updated 03/17/2013 at 7:34 pm by
Jende Industries.
03/01/2013 at 4:43 am #9841
Thanks for the reply Phil. I was rereading the thread… and I saw earlier you had already mentioned that a 1K/2K set would be good after the diamonds if you could get them, so I think I misread where you said you need 800/1000…. it’s more of “get that if that’s what you can get”, cause that’s what’s offered by WE. π But the additional info sure helps clarify things.
Sauce, I don’t know if they can be made up different than what’s offered… just me thinking out loud.
03/01/2013 at 5:26 am #9842Sauce, I don’t know if they can be made up different than what’s offered… just me thinking out loud.
Sure, by third parties. Steven Pinson or Ken Schwartz could make you up a set with whatever you want. 800/1000 400/1000 Whatever.
All my Chosera and Superstones are from Steven and he does great work. I’m sure Ken’s are too.
My Choseras are 400/600 & 800/1000 and my Superstone are 2k/8k & 10k/12k I rarely go above 2k for a regular working knife but I’ve taken a couple up to 12k and they are gorgeous.
Ken
03/01/2013 at 5:31 am #9843If I wanted to eliminate the sand paper, where would the choseras most effectively fit in here?
Before or after ceramics?
Personally, after the 800/1000 diamonds I’ll go back to the 400 Choseras if I’m going that route. If I’m using the ceramics, I stop after the .6ΓΒΌ. I suppose the 2k Chosera or SS would be a good follow on but I’ve not done it.
Ken
03/01/2013 at 6:29 am #9845Well you guys are making me rethink what I’m doing and I’m grateful! My original route was to go with the new arms and 2k/3k choseras? Now I’m going with Phil and if I have this right? A set of
800/1000 choseras followed up with a set of 2k/3k choseras and that I really do not need the upgraded arms? A new set with the new washers would be fine? Sorry to veer a little of thread?03/01/2013 at 7:20 am #9846Great thread :woohoo: – Eamon suggested I jump on and take a look.
Great information from everyone – I find jumping from the 1000k diamonds to the 2k Chosera to work great for me – the caveat, I realize, after reading this is that my 400 thru 1000 diamonds have done several thousand sharpenings. I had realized that they perform different than what most people experience since I usually have a shine starting already when I’m done with them (and I remember early on being jealous of how Clay’s knives were shining after 1000 diamonds), but hadn’t really thought about how it affected my transition to the Choseras :blush: – obvious now but funny how I think about that in discussing strops and ceramics but hadn’t connected it for the choseras
I digress though – I agree with Curtis that you can get to the mirror with the ceramics and strops (and that bragging rights don’t come cheap in $ or time :dry: ) It does take substantially longer – and the ceramics do make the difference. Without the ceramics I don’t know that it is possible through just stropping alone (at least not if you do all the other work with diamonds, which is the point here anyway isn’t it :whistle:) and adding the microfines to the grit progressing helps immensely.
And I agree you get to a polish faster with the chosera or shapton stones (well really anything that doesn’t work as aggressively as the diamonds do). Phil and Ken’s statements about backing up in grits make great sense to me given the aggressiveness of the diamonds – guess I’m gonna need to break out some new diamonds and try it out.
Using any stone that wears over time is a case where I definitely suggest having and using the ball joint arms – and when using stones that vary significantly in thickness. Making the angle adjustments when changing stones is much easier with those arms than with the basic kit arms. Not that you can’t do it with the basic kit arms, a lot of us have for a while now, but it is so much easier being able to drive the ball joint in and out a little to match the angle.
And – shameless self promotion warning!!! πΏ I build custom handle set of atomas, choseras, shaptons, strops etc…. as well. And we should add Tom at Jende to that list also
03/01/2013 at 11:21 am #9848Well you guys are making me rethink what I’m doing and I’m grateful! My original route was to go with the new arms and 2k/3k choseras? Now I’m going with Phil and if I have this right? A set of
800/1000 choseras followed up with a set of 2k/3k choseras and that I really do not need the upgraded arms? A new set with the new washers would be fine? Sorry to veer a little of thread?Bob is right about the arms… they make things a bit easier when changing stone thickness. That being accepted… If I had the coice between a set of stones and the new arms… I would go with the stones every time. Bob pointed this out too, but I will say it with emphasis… I used the original arms for over two and a half years, and never found using them to be a handicap. I agree, the new ones are incrementally better, but you can get as good an edge with the original arms…and the arms don’t sharpen the kinife, the stones do.
The newer arms set will not get you a mirror edge, but the right stones will.
It is all a matter of priorities (unless one has unlimited funds, then get it ALL π ), mine would definitely be with the additional stones.
03/01/2013 at 11:41 am #9849If I had the coice between a set of stones and the new arms… I would go with the stones every time. Bob pointed this out too, but I will say it with emphasis… I used the original arms for over two and a half years, and never found using them to be a handicap. I agree, the new ones are incrementally better, but you can get as good an edge with the original arms…and the arms don’t sharpen the kinife, the stones do.
+1 on that – thanks for the emphasis Phil (and for sharing all your experience with the Choseras), couldn’t agree more :cheer:
03/01/2013 at 12:04 pm #9850Ok guys, a lot has been thown out in this thread. What I am wondering is since the 5 and 3.5 diamond paste are ( 5 and 3.5 are microns) and the 1200 and 1600 ceramics are ( 5 and 2.85 microns) won’t you get about the same finish by using either the ceramic stones or the paste as far as a mirror finish goes?
03/01/2013 at 1:01 pm #9851Ok guys, a lot has been thown out in this thread. What I am wondering is since the 5 and 3.5 diamond paste are ( 5 and 3.5 are microns) and the 1200 and 1600 ceramics are ( 5 and 2.85 microns) won’t you get about the same finish by using either the ceramic stones or the paste as far as a mirror finish goes?
I will look for threads later where we as a community have tossed this around before…
Now I will just say, not really.One of the things that I really struggled with when I got back into precision sharpening several years ago was separating grit ratings from reality. ( I have been sharpening for over 50 years, and always have been OCD. Alway happpy with my results…then came the Internet and unlimeted DIS-information…damn :unsure: )
The ceramics, the Shaptons, the Choseras, Atoshis… etc… and above all the the different pastes all act entirely differently when applied to steel.I can’t emphasize this enough, grit size is an extremely rough guide to understanding what an abrasive does at the edge. You need to know the shape of the abrasive, you need to know how it fractures under pressure, you need to know the concentration of the abrasive, you need to understand the binder and the stiffness of the substrate, ..Then you may begin to know what it does at the edge. Then you will have to understand how all of the previous data applies to different steels..
Then you will give in and figure out that you just can not compare abrasives by reading about them or comparing charts of grit sizes.The ceramic stones do not have a specific grit. They are measured in surface roughness and loosely translated into a grit rating. You simply cannot directly compare them, other than using them and observing the results, to any other abrasive…period.
Clay has talked about this specifically. I can’t now find the thread. I think that Syderco uses the same manufactuer as the WEPS gets the microfine ceramics from, Coorstech… here is a quote from Sal…the owner of Spyderco
“I would be curious as to where you got your numbers for the ceramic stones. All of the ceramics use the same micron size (15-25). the different grits (equivalents) are created by different carriers, different firing techniques and diamond surface grinding.
sal “
http://www.spyderco.com/forums/showthread.php?31188-Ceramic-benchstones-compared-to-DMT-extra-fine
The pastes are also very hard to compare to anything, except other pastes in the same line. It has been well established that a one micron paste from one manufacturer will show significantly different results.. through actual photo micrographs, than that from another. The biggest difference here is concentration of the abrasives. But it goes beyond that. There are mono and poly crystaline diamonds and there is CBN. All can be rated at a specific micron size, but the break down differently. They can all be rated at the same micron size as the mean, but the distribution around the mean will be different.
Bottom line, the ceramics will do a specific thing for you, they will cut consistently. Once you know what they do, you can employ them effectively in your progression. When you try to compare a specific micron size of paste to an equivlently rated ceramic… well you can’t!
The WEPS diamond pastes will give you some polish, and the will remove some scratches…given time. As Clay has shown, they will refine an edge. In any reasonable amount of time, they will not do what the ceramics do as far as removing metal.
Take a look at these links.. hopefully you will get an idea of where I am coming from.
http://www.wickededgeusa.com/index.php?option=com_kunena&func=view&catid=5&id=2399&Itemid=63
http://wickededgeusa.com/index.php?option=com_kunena&func=view&catid=14&id=4555&Itemid=63
Just a mea culpa here.. I have spent countless hours in the past calculating grit siazes of different abrasives and buying things based on that. I wasted lots of money and time. I have countless stones, slurrys, abrasive papers, coumpounds, glass plates, granite plates…. only to find I don’t use much of it at all.
Better to listen and learn and sharpen more, than to compare charts…
πPhil
03/01/2013 at 1:48 pm #9852Thanks Phil. I guess the best way to understand the intracasies (not sure I spelled that right) of knife sharpening, other than reading this forum (which is awesome) is to do some experimenting with different stones, ceramics and pastes in different combinations to see what results I prefer. I get the jist of what you were saying, just trying to reduce as many trial and errors as possible.
WE just sent me an e-mail letting me know that my PP1 was mailed out yesterday so I should receive it around Monday and that is when the fun starts. I doubt I will ever have 50 years experience under my belt as that would put me well over 100 but I’ll have fun trying to get there. π You and many others on this forum seem to have extensive knowledge about sharpening so I’ll most likely be picking a few brains.
Thanks again for the information.
03/01/2013 at 2:11 pm #9853I doubt that you would have had time to look at the links I listed in my reply above by now in their entirety…
Please take the time to do that. You will learn much. Both are pretty long… but it took a long time for Clay to document the information… this micrograph thing is time intensive..
You we will be well served by going through every frame.. and every comment…and absorbing it all!
I promise!http://www.wickededgeusa.com/index.php?option=com_kunena&func=view&catid=5&id=2399&Itemid=63#2399
There is no instant gratification in this art… but all of the time you take in research will be rewarded in the reduction of the slope of learning curve that you must traverse.
03/01/2013 at 2:53 pm #9854Thanks again Phil. I watched the second post but was unable to access the first. Then error advised me to contact the system administrator.
There was a load of good information in the second post which cleared up some things for me.
03/01/2013 at 3:18 pm #9855I fixed the link π
03/01/2013 at 4:13 pm #9856The first is maybe the best…when talking about stropping..
Thanks for fixing it Curtis !!
Phil03/01/2013 at 4:44 pm #9857Phil thank you so much for all of your hard work! There is so much here it is hard to take it all in and digest it all. I will however follow your lead and buy the choseras. I spoke with Bob at Oldawans again today and he is going to make up some customs stones for me. We decided on 1k/2k and a 3k/5k stones. I’m not a well to do sort of guy? But I am going to get the ball joint arms as well.
Hopefully this will hold me over for a little while? Thank you again! -
