hard to clamp - nice little knife
Berreta…25* matching angle at clamp spot
That blade must be made with some fairly thick stock. The bevels are quite wide for 25 degrees per side. It turned out nicely!
What is the problem? If the knife does not hold well in the clamp, use a piece of chamois to clamp it. If the stones hit the clamp, use the Tormek small knife adapter.
Couldn’t agree more Mark, the tormek small knife adapter is a must for me.
Great for fillet knives, a lot of folders, and you don’t have to worry about damaging an expensive knife.
