Wicked Edge Professional Series Sharpener
Recent Forums Main Forum Product Announcements Wicked Edge Professional Series Sharpener
Viewing 15 posts - 16 through 30 (of 32 total)
  • #17852
    Craig
    • Topics: 4
    The wicked edge Master pro pack! Lol
    #17855
    I actually like Commercial.
    You could call it the iPhone 6,,,, think of the web traffic and free publicity (from the lawsuit) you’d get. 🙂
    #17861
    Geez guys… I should have used one of those little smiley face doomajiggies. 😛 It was meant as a joke. I thought “Professional” was just fine.
    But if you’re in the mood to change the name, it occurred to me that what’s different is that this new package is an integrated system. The existing Pro Pack was already a professional sharpener compared to the other systems out there. The new pack has an improved “clamp on center” feature, but otherwise, the main feature is that it does put everything in one gadget. For pros, the big difference will be set-up time at the shows. Nicht wahr?
    BTW, the other night I watched your video on how to sharpen straight razors on the Pro Pack, by rotating the pivot blocks 90 degrees to move the pivot point off center, relative to the clamps. Very, very clever. Will the new system still allow you to do that?
    #17863
    Gib Curry
    • Topics: 18
    Of course, this means I’ll have to stop referring to my WEPS PP2 as a “professional grade” sharpener.
    Nah, the PP2 is definitely professional grade. The new one probably should be called Commercial or Industrial, I just didn’t like how that sounded. If anyone has a better name suggestion, it’s early enough that we could still change it.[/quote]
    To me Professional did separate it from the Pro-Packs and Field & Sports — all three “product categories” are “professional” quality sharpeners.
    I can see the potential that there are more choices added to all three product levels/grades/designations.
    That being said, here’s the quick list that came to mind for me…..
    Master Series/Edition
    Industry Series/Edition
    Trades Series/Edition
    Production Series/Edition
    Market Series/Edition
    Again, though, I feel the name already distinguishes it….
    For Now,
    Gib
    Φ
    #17864
    I’ll have to test if the new system will work for straight razors and get back to you.
    #17989
    Les Garten
    Hello,
    Very nice looking product. Can you provide some details about the advantages this system has to offer over the Pro 2 for instance?
    Like the angles achieved and the differences in the clamping mechanism if any?
    etc, etc
    $900 is a tuff nut to crack over the PP2. For someone new to WE, it would be nice to have some bullet points of all the differences/advantages.
    Drawbacks would be nice as well if there are any. Like is there something the PP2 would do that the Pro Series would not.
    #17990
    Mikedoh
    #18015
    tuffy braithwaite
    • Topics: 184
    i am saving 🙂 🙂 🙂
    #18882
    Lukas Pop
    • Topics: 10
    What is the angle range?
    #18926
    Les Garten
    :ohmy:
    I just saw the price increase on the Professional Series!!
    I’ve been saving all my pennies and nickles for this and just got where I needed to be and the price goes up!
    You’re killin’ me here!
    Looks like my Edge Pro Professional will have to continue it’s metal scraping for some time…
    #18933
    keep in mind this professional sharpener is for speed AND precision. it has a self centering/adjusting vise and does not have any micro adjustment. so if you are one of those people like me that likes to REALLY fine tune your angles (to match something else or to account for blade geometry issues) then this may not be for you.
    it is my understanding that this is primarily designed for those who have a business sharpening or for professional kitchens. =) hope this helps! If I am wrong on any of these above points I am sure someone will correct me…
    #18934
    12-35, depending on the blade width.
    #18935
    It does have the micro-adjustments, so it’s basically like the Pro II. With the Professional Series, the gross angle settings on the two sides are adjusted with one control, limiting the difference in angle you can achieve between each side of the blade to the 3 or so degrees you can adjust with the micro-adjustments. Thankfully, very few knives are sharpened with different angles on each side. Most asymmetrical knives have the same angle on both sides and have just been sharpened with more emphasis on one side versus the other.
    #18936
    Thanks clay for clearing that up!
    #19084
    Jeff
    That looks great Clay. I see a lot has changed since i first purchased my set, not even named the pro pack, at that time. I just asked you what would be the best and you set me straight. I wish you could have sent out an email regarding the upgrade you had for the arms, riser and calibrated bar. I would have jumped on that, but now will just make due with my set and all of it’s flaws, which it looks like you’ve corrected. Keep up the good work, sorry i missed out on the new upgrades. But your product has kept me sharp all this time.
