Touching up the edge
  • #6209
    Phillip Hyun
    • Topics: 4
    I don’t need to reprofile or start at 100 grit to sharpen my knife. I want to touch it up a bit. Where do you start for a touch up? 400? 600? Thanks!
    #6212
    If you’re using a marker to help identify the angle and you’re sure you’re hitting the apex of the edge with the stones, you should be fine with the 600# stones.
    #6219
    Phillip Hyun
    • Topics: 4
    I do use a marker as well as careful set-up measurements to the mm. Should I be feeling a burr at 600 before moving to 800?
    #6229
    If you’re using good magnification to examine the edge and verify that the marker is all gone then you probably don’t need to go all the way to a burr but if you’re not sure you’ve reached the edge then working to raise a burr will be important.
    #6230
    Phillip Hyun
    • Topics: 4
    Thanks. I should probably invest in a good magnifier. Any suggestions on magnification level?
    #6235
    There are a bunch of magnifiers available on Amazon. Here is the little one I use and I’ve been very happy with it: 60x Lighted Loupe.
    #6250
    Phillip Hyun
    • Topics: 4
    Thanks Clay!
    #6263
    Tom Whittington
    • Topics: 4
    I still can’t get over how easy touch ups are. I thrashed my Hogue chopping saplings just to torture it, and rolled over part of the edge. A minute or so with the 1000 grit diamond stones sorted it right out using my noted settings. I think that’s another good reason why so many folks here mention the 1000 grits for daily use; they strike that balance between an attractive matte finish and being easy to touch up with.
    I also need some magnification one of these days, if anything I’m horribly guilty of overdoing the burr now and then!
    #6265
    Phillip Hyun
    • Topics: 4
    Amen brother! Me too!!! I just ordered one of those nifty 60x lighted magnifiers that Clay suggested. Dirt cheap!!!!
