Spyderco question
Viewing 15 posts - 1 through 15 (of 22 total)
  • #10556
    John Batinovich
    Hey all,
    I’ve had my WE a couple of weeks now, during which time I’ve been going through the usual learning curve. My first success was with my S30V Paramilitary 2, which I was able to get a real nice edge on. My issue is the heel of the blade. While I was able to sharpen the rest of the blade like I wanted, the stones don’t reach into that little nook formed by the finger choil, so now there’s a little notch there. How do the rest of you handle this or is it just the function of the sharpener on this kind of blade?
    #10579
    John Batinovich
    Wow, 21 views and not one of you has experienced this?
    #10580
    Mark Massie
    • Topics: 9
    Some folks have stated that they helped this situation by grinding off the plastic edges of the stones to be even with the diamond plates. For me, it was not worth the effort for such a small area.
    #10583
    I had the same problem and this is exactly what I did… Took it on my belt sander for a short bit no problem now 🙂
    #10587
    Ken Buzbee
    • Topics: 14
    Those are your two main options. I suppose you could jury rig a solution but if this is a concern AND a regular occurrence I’d just remove the shoulders from the stones.
    Ken
    #10593
    John Batinovich
    Thanks for the replies guys. It’s not a big deal, not big enough to grind the blocks down.
    #10813
    Kyle Mazur
    i had the same problem and it drove me NUTS. my solution not really cost effective. i went out and got the choseras. since they’re thicker they clear the choil on the para 2
    #10822
    John Batinovich
    Thanks Kyle. I’m not quite ready to go the Chosera route, but I’ll keep it in mind.
    #10841
    Phil Pasteur
    • Topics: 10
    Clay has suggested that you can pull the plates and add a layer between them and the platen…
    The layer being whatever you can cut and lay down to fit of the desired thickness.
    Maybe grinding the plastic would be easier…
    It doesn’t take much additional thickness. a credit card thickness of plastic would likely get you there. I just put up with the issue until I bought some Chosera stones…
    I am real glad that I got them..!
    #10846
    Jose Fuste
    • Topics: 4
    I managed to work on that small corner by lifting the blade handle while on the WE. While doing this I was able to reach it.
    #10847
    Phil Pasteur
    • Topics: 10
    good move..
    Always more than one way to skin a cat.
    You will change the angle slightly by doing that though…
    #10848
    Jose Fuste
    • Topics: 4
    Not really, the blade remained in the same position, the only thing I did was flex the handle upward to reach the actual blade tail.;)
    #10849
    Phil Pasteur
    • Topics: 10
    I see, you unlocked the handle and moved it. Interesting, I never thought…having had the same issue myself, that moving the handle would give any extra clearance.
    I have a few Paramilitary 2 knives. I will have to check it out. It really stopped being a problem since I have had thicker stones, but it would be nice to be able to do for those jobs that are OK with the stock WEPS diamonds and ceramics.
    #10850
    Jose Fuste
    • Topics: 4
    Exactly….:cheer:
    #10863
    John Batinovich
    Say hey, Jose,
    I’m not quite clear about what you’re suggesting. Are you changing the angle of the entire knife in the clamp? Since the stone is hitting the forward-most part of the finger choil, it’s not clear in my mind how that would work. If you could clarify, I’d appreciate it.
    Thanks!
    John
