My 2 cents.
Figure out the grit on your steel … lets say its 600.
Someone point out if I’m wrong, but wouldn’t taking say a 2k edge to a 600 steel give it more tooth .. or if you look at it another way, downgrade it.
Takes the edge to the lowest common denominator.
Now that might be great for cutting up a pork butt with tendons, but not for other things.
I’m a huge fan of the 1200 grit Idahone.
As a bonus, you now have 2 grades of steel/ceramic that you can use and choose for the job.
The Idahone is harder than the metal, takes a nice lite touch, and, as a bonus, when you get used to it, you can actually hear when you are on the edge, the apex, or the high line.
I kid you not.
Plus, do you really want to take your paper thin slicer to a 400 – 600 grit steel?
Any thoughts?
And at $32? for a 12″, a bargain.
Just don’t drop it!
