resin bonded diamond stones?
Recent Forums Main Forum Techniques and Sharpening Strategies Abrasives resin bonded diamond stones?
Viewing 2 posts - 16 through 17 (of 17 total)
  • #57229
    • Topics: 84
    I’m still very very curious if these bonded matrix stones are still in your mix @MarcH. happy thanksgiving, and let us know your current thoughts on this set-up!
    Yes, the Resin-bonded Diamond Matrix Stones are still in my arsenal.  I can’t report any more details then I already posted earlier in this thread.
    These Resin-Bonded Diamond Matrix stones have their pros and cons:
    Pros:
    • they don’t have any real break-in
    • they don’t shed diamond dust like the W.E. stones do (during beak-in)
    • they work very similarly to the W.E. diamond stones laying down similar predictable and  consistent scratch patterns, comparing grit to grit
    • it is a fun do-it-yourself home project to make these stone sets
    • they fit and work well with the W.E. set-ups
    • they are slightly larger in stone surface area
    • they yield sharpening results just like those from the W.E. Diamond stones
    Cons:
    • they are an expensive project/investment
    • you have to order and purchase these already-made stones then modify them to apply them on W.E. paddles
    • these stone sets will have no warranty because they are a modified custom project
    • these stones are non-magnetic so you can’t use a magnetic angle cube as simply as you do with the magnetic W.E. diamond stones
    • these stone sets are not maintenance free; they will need lapping when worn or dished
    • these Matrix stone sets are slightly larger and somewhat heavier in the hand, to work with them
    • these Matrix stones sets do not yield sharpening results, (when used similarly to the W.E. set), that are noticeably improved or really any different than the results from well broken-in W.E. Diamond stones to justify the expenditure and the work to make these
    • they are another set of stone handles you’ll need to make room for in your collection or storage rack
    • at times, you may still need alternative sharpening mediums when diamond stones are not appropriate or not preferred for all the different steels you may be sharpening
    Happy Holidays to all!
    #57230
    Henry
    • Topics: 4
    Much obliged!
