Rapalla fillet knives
Recent Forums Main Forum Techniques and Sharpening Strategies Rapalla fillet knives
  • #25144
    Bart LaMont
    • Topics: 5
    Does anyone have any tips or tricks on sharpening the Rapalla fillet knives with the birch wood handle? They are so flimsy that I seem to not get any where with mine sharpening on the pp1
    #25145
    Aaron kimpton
    • Topics: 8
    The martini filet knives?
    I usually work in 2 inch sections down to 1000 grit.
    I have a buddy making a 2.5 inch low angle bracket for me. This should help with being able to do 3-5 inches at a time.
    #25147
    Daniel maloon
    • Topics: 10
    +1 on doing it in sections
    I’m interested on seeing what you make. I was thinking of something like this but never got around to building it. I just don’t get enough of them to make it worth it
    #25149
    Aaron kimpton
    • Topics: 8
    This is what he made for me
    #25151
    Bart LaMont
    • Topics: 5
    I dabble with some mill and lathe work maybe I’ll give something like that a try, thanks for the ideas
    #25152
    Daniel maloon
    • Topics: 10
    Very cool
    #25153
    I did a number of Martiini filet knives this winter – maybe 10 or 15. I did a lot of searching but I never did find out what the correct angles are. You gents have any luck there?
    BTW, I clamp the knives with only about 2″ of the tip extending beyond the vise and I hold the handle with the opposite hand to reduce deflection on the near end. Yes, I do one side at a time – maybe 10-20 strokes per side, the switch, repeat…
    #25167
    Aaron kimpton
    • Topics: 8
    I did an old US made Schrade Filet knife, and an Bubinga opinel filet knife. 14.5 dps on each. It required doing one side at a time. Same as all the martinii knives i have done. Take it slow.
    The Schrade knife seemed to do better finished at 800 grit. The opinel was the inox version, It finished down at 1000 grit nicely. I could have went for more, but i find the filet knives do better with a bit of teeth.
    #25198
    jimbo45
    I just did my martini a couple of weeks ago and wish I had done it how did
    #25201
    Zamfir
    Clamp the tip and support the handle. That is all that is needed. Works awesome. I did that on a knife more flexible than the Rapalla.
    https://knife.wickededgeusa.com/forum/10-advanced-techniques-and-sharpening-strategies/13328-technique-for-long-flexible-knife?limitstart=0&start=10#20497
