I suspect my manix 2 will need sharpening in a few years being s110v
But I’ll be more careful when I do my domino, honestly thinking of buying the ball joint arms before I do that though, the factory grind line is just so perfect.
Few Years?? You need to cut more stuff man.
I need to sharpen my zdp-1089 Cali every Month or so, and that is a tad bit harder than the s110V. Or are you one of them folks that carries a different knife every day and have like 50 of them? All the tips mentioned are great. It is more than likely a combination of them all making a difference. Biggest key for me was understanding the sweet spot and where the angles are the same and where and how they change in the geometry of the stones on the arms in respect to the way the blade is mounted in the vise.
This is new to me.. might help..
http://www.wickededgeusa.com/does-the-angle-change-along-the-length-of-longer-blades-on-the-wicked-edge/
Maybe this will help also.. The old circle and line being at the same angle talk. the visuals is what helped me the most..
https://knife.wickededgeusa.com/forum/2-welcome-mat/13542-sharpening-the-zt-0900#23240
