Next purchase … need ideas
Recent Forums Main Forum Stropping Next purchase … need ideas
Viewing 15 posts - 16 through 30 (of 47 total)
  • #18651
    Leo Barr
    • Topics: 26
    You may consider glass for films it makes for the best backing for films .
    Sent from my iPad using Tapatalk
    #18653
    Those are cool tcmeyer. I went with aluminum but i think ill try to go down to tap plastics and see what u can find
    Hi Dan: I’ve been making a final version out of Garolite, a plastic akin to phenolic. So far very machinable, glues up easily. One of my wood versions (poplar) must have absorbed enough moisture to have the bushings go out of alignment.
    Learned the hard way that the glass should have the edges polished. A sharp corner will leave a nasty scratch on a pretty knife.
    I too am looking forward to WE coming out with a glass-platen version. I think it’s an excellent step forward.
    #18665
    drew
    • Topics: 4
    ok so after I used the 1200/1600 fine stones … should I go leather strop 5/3.5 micron and then roo strop with 1/.5 micron ?
    I am thinking that would be a good progression to see how it goes… and then if I am not happy with the edge I could go even small micron with a nano cloth or something?
    I found this …
    [table]
    [tr]
    [td]Grit[/td]
    [td]100,000[/td]
    [td] 50,000[/td]
    [td] 14,000 [/td]
    [td]6,500[/td]
    [td]4,500[/td]
    [td]1,800[/td]
    [td]1,400[/td]
    [td]1,200[/td]
    [td]1000[/td]
    [/tr]
    [tr]
    [td]Micron[/td]
    [td]0.25[/td]
    [td].5[/td]
    [td]1[/td]
    [td]3.5[/td]
    [td]5[/td]
    [td]9[/td]
    [td]14[/td]
    [td]15[/td]
    [td]18[/td]
    [/tr]
    [/table]
    #18669
    So.. if you’re still interested in achieving a mirror edge, the grit progression you list above is perfect. Wicked Edge users have been attaining mirror edges with the 4 or 5 sets of stones and a couple of strops for a long time, but expect to work at it. Most have moved up to the higher-end stones to fill in the middle grits. If you decide to focus on getting your knife to cut, think in terms of a toothy edge and start stropping with the 5/3.5 after 800 grit or so, but at two degrees less angle.
    #18671
    +1
    #18675
    drew
    • Topics: 4
    Sorry for the ignorance … but why -2 angle?
    #18681
    Leo Barr
    • Topics: 26
    It is recommended that dropping the angle by 2˚ per side because leather strops that have a tiny amount of give in them so they will round off the point if you continue with the same angle as the stones. You should also reset the angles when switching different sharpening mediums particularly with the ceramics , Choseras and the different strops since all will have different thicknesses .
    #18682
    drew
    • Topics: 4
    Ooooh ok I never would of thought about that. Thanks for that info!!!
    #18712
    drew
    • Topics: 4
    Well I ordered my next round of blocks and strops … I am hoping it works out as well as I am thinking …
    #18717
    You can’t go wrong with your selection! Well… be careful. Strops easily nick.
    #18744
    Duane KLimczyk
    What should be done differently when using the ceramics?
    #18745
    drew
    • Topics: 4
    In what context?
    #18757
    Duane KLimczyk
    The question was in regards to the previous statement
    #18759
    Leo Barr
    • Topics: 26
    I would highly recommend this
    Variable Stone Thickness Adapter
    This was inspired by the drill stop collar for the Edge Pro it makes for easy precision sharpening I know from my Edge Pro that the tapes 2-4-6K tapes used to tear without the drill stop collar with this the angle was absolutely precise so for the incredible cheap price the thickness adapter is I would highly recommend it excellent for the transition from diamond plates through to ceramics or Choseras or even once the angles have been dropped for strops once again great for strops of different materials it makes a huge difference to the quality of the edges you will turn out you will wonder how you survived without it .
    #18771
    drew
    • Topics: 4
    So are you saying from like a 200-100 grit range is one angle … 1200-1600 is a smaller angle by like 1200-16002 degrees then strops are even small by another 1200-16002 degrees?
