Maxamet? Weird results
Recent Forums Main Forum Maxamet? Weird results
  • #38711
    Ken Buzbee
    • Topics: 14
    Hey guys, been a while.
    Had a weird experience sharpening a Spyderco Native 5 Maxamet and wanted to see if anyone had different (or better) results.
    Ran it through the Atoma plates 140->1200 at 12° per side but the final edge (under 20x loupe) looks wavy, not the crisp uniform grind I’m used to. Any thoughts?
    I guess it could be the high carbide volume? Just not sure. I haven’t run into this before,
    Thanks
    Ken
    #38740
    Any pics of the edge with your scope Ken?
    #38750
    Ken Buzbee
    • Topics: 14
    I don’t, but this is a picture Cliff Stamp posted that is pretty similar
    #38752
    Ken Buzbee
    • Topics: 14
    I found it interesting that his pictures showed the same scenario I’m seeing. Maybe this is just the way Maxamet behaves but I wanted to see if anyone here has seen the same thing.
    Sharpening it was very odd. I thinned the edge a lot (which took FOREVER) but as I was forming the apex the edge seemed to crumble away (for lack of a better term) Initially I thought maybe it was over heated during the factory grind, I’ve seen that before. But the further I took it, it just kept happening.
    The thing I can’t (okay, can’t EASILY, haha) get through is the pieces that seem to fall out are way larger than the grit in on. So, the 140 plates left huge “chips”. As I moved down in grit size, that improved but the “chips” at each level were 15x the size of the grit being used. I would not normally be trying to remove something that size even with the grit I was on, let alone going down another level.
    By the time I was using the 1200 plates it seemed like I was just polishing the peaks. 1200 grit would take 40,000 stokes to remove what I’m seeing (this knife already has 6,000+ Strokes on it, just to get to this point.
    Unless someone here has some better ideas, I think I may widen the angle and see if I can refine just the edge with ceramics or diamond films. Even if that works I think it will be a long process and not leave the edge I was trying to get, but that just might not be possible with this steel.
    #38753
    Yeah try adding a microbevel and see how it does… That’s super interesting, I don’t have any experience with maxamet that I know of
    #38755
    Sharpening it was very odd. I thinned the edge a lot (which took FOREVER) but as I was forming the apex the edge seemed to crumble away (for lack of a better term) Initially I thought maybe it was over heated during the factory grind, I’ve seen that before. But the further I took it, it just kept happening. The thing I can’t (okay, can’t EASILY, haha) get through is the pieces that seem to fall out are way larger than the grit in on
    I have shared a similar experience, (I wrote about in an earlier thread on this Forum) when sharpening some Japanese Kitchen knives made of SG2 Steel that is categorized as “Powdered High Speed Tool Steel” or “micro-carbide powdered Crucible Steel”. This steel is Cryodur Ice Hardened to Hrc 62 or 63. I now only sharpen these type of knives with wetstones. The smoothest edge I can get still has very tiny microchips down the bevel visible only at high power with the USB mscope. The knives are very sharp and very durable, just a PIA to sharpen. I do sharpen them at 14 dps. ….I looked up Maxamet for the type steel in your knife: Spyderco says it’s hardened to Hrc 67-68.
    #38756
    Ken Buzbee
    • Topics: 14
    I saw your post after I posted and thought ‘gee, that sounds very similar’!
    Good advice. I’ll get both wetstones and ceramics a shot and see what happens.
    Yeah, Spyderco ran these pretty hard from what I understand. Could be part of the issue along with the carbide volume.
    Thanks guys!
    Ken
    #38757
    I saw your post after I posted and thought ‘gee, that sounds very similar’!  Could be part of the issue along with the carbide volume. Thanks guys! Ken
    Ken I tried to get a Forum Category on Sharpening Super Stainless Steels going but no one cared to follow or contribute. I really think these steels are a totally separate animal requiring a little different finesse or sharpening technique. Thanks
    #38758
    Ken Buzbee
    • Topics: 14
    I’m coming to agree about that. Great idea.
    Ken
    #38759
    It was in the forum under: Technique and Sharpening Strategies, Advanced Techniques and Sharpening Strategies, Sharpening Japanese Stainless Steel and High Speed Tool Steel
    Thanks
    #38764
    There’s some who eschew diamond sharpening, claiming that it doesn’t cut as smoothly as waterstones.  I wonder if this sort of experience drives that thought.
    What you describe here is almost exactly what I saw when I tried to sharpen ceramic knives.  No matter what grit I seemed to use, pieces of the edge would break off, leaving a ragged edge completely different from what we normally see with steels.  It’s almost as though I was applying too much pressure against a too brittle edge.  So I’d question if the steel in your Maxamet is doing the same thing.  The hardness claimed by the maker isn’t always accurate.  They might be using the correct heat-treating formula for a batch of blades in this steel, but there might be a “fly in the oinment,” such as too much chromium.  They may also have erred in the quenching or cryo procedure, leaving the edge way too hard.  Fact is, I really don’t know squat about steels beyond what I read here or see at the WEPS, so I’ll tag it as “For what it’s worth.”
    #38765
    Ken Buzbee
    • Topics: 14
    Agreed TC, it is kinda like what you see on ceramic blades. A bit less regular (more random) but good analogy.
    Ken
    #38770
    Ken Buzbee
    • Topics: 14
    Thank you, guys! Switching media was exactly what was needed. I’d become so enamored of these Atoma plates and the slightly toothy edge they leave that I’d kinda just packed everything else away for the time being.
    But (apparently) that won’t work for these very hard, high carbide steels. (At least I can’t do it) Switching over to the micro ceramics left a beautiful clean edge on the Maxamet. Revisiting my K390 Urbans, I actually noticed the same phenomenon. It was much more subtle and I hadn’t spent the time to really look at the edge, but once I did, that same wavey/chippy edge could be seen, just several orders of magnitude less than on the Maxamet. Didn’t take long on the micro ceramics to clean those up too.
    So, going forward, on these hard/high carbide steels, I still plan the use the Atomas to thin the edge if needed, but once I get near the apex I’m going to switch out to water stones and/or ceramics to finish it up.
    Great analysis and resolution, guys! Well done.
    Ken
    #38776
    Mjcollier
    • Topics: 13
    A 24 degree inclusive bevel may be to steep to support such a carbide heavy steel. Cutting the apex off and then putting a 30-40 degree bevel micro on may help.
    #38778
    Ken Buzbee
    • Topics: 14
    Yeah, I’d kinda had the same thought, but I wanted to try it and see. I’d thought the edge might not stand up, but I didn’t think I wouldn’t even be able to form it.
    In a sense that’s exactly what I did, but doing the “micro” (It’s larger than I’d consider a micro) with the ceramics really helped out the process. Still a great cutter even with the wider edge.
    Ken
