Aloha Ravenbrook,
Mr. Wizard and a fellow named Komitadjie both have made serious attempts and put ALOT of effort to make similar versions of a Comprehensive Grit Comparison Chart.
Wizards is here: http://myplace.frontier.com/~mr.wizard/GLGC/GLGC.png
Komitadjie’s is here: https://docs.google.com/spreadsheets/d/1VaTf3MXuwuvH-QLwOci4f9B9Zhkbuu1wjoSCZIUsR-o/edit#gid=0
I havent double checked that the values line up for every single thing between charts but Id guess the results are very similar for what we are interested in. Mr. Wizard at one point even mentioned Komitadjie as his inspiration in doing his own independent version. Thanks to both of them!!!
I also use sandpaper strips in the higher end area with great results. The confusing part is there are at least 3 or 4 grit “standards”.
Here is a quick read to see the differences: http://sizes.com/tools/sandpaper.htm
Hopefully Mr. Wizard can correct me if I am getting this wrong but most sandpaper here(U.S.A) is in the CAMI(Coated Abrasive Manufacturers Institute) scale. I have found the very fine grit wet/dry auto paper usually has a designation of “P” in front of the number, p2000, p2500, p3000, etc. There is a BIG micron difference between these types.
If you look on either chart you can see the WEPS 1000 grit stone is at 7u(microns). Compare that to p2500 grit paper at 8.4u. What you will hopefully find in following the 1000 grit WEPS with the p2500 is that the p2500 can leave a much smoother uniform finish(almost mirror smooth in appearance) I follow that with p3000 which is technically the same micron rating as the original WEPS 1000 grit stone, but there is a WORLD of difference in how it looks.
After that you are nearly at the finish line. You can choose micron abrasive films or paste/strops to finish off to a sweet mirror finish. If I had p5000 (5u rating), Id use it in a heartbeat and go straight to strops! B)
Another neat trick is to take the last grit of paper and go directly sideways along the edge bevel, leaving a perfect satin finish with no scratch lines, even tho you dont take it to mirror finish. I then come back and sometimes put a micro-bevel with the same paper on top. Good fun!!! Hope that helps…
