First good knife on the WEG3Pro
Recent Forums Main Forum Knife Photos First good knife on the WEG3Pro
  • #49847
    Ralph
    I got my Wicked Edge Gen 3 pro a few days ago. For some reason, they don’t sell a pro pack 3 with the gen 3 pro, so I had to buy the additional stuff separate. I broke in the stones with some cheap kitchen knives. I then put a nice mirror edge on my Benchmade 940. Those lapping strips work excellent! I may buy some more of those in different grades. The 940 came out scary sharp, and the mirror edge looks fantastic! I took off the little thumb thing on the 940 to sharpen it, then put it back when I was done.
    #49854
    Good job on your Benchmade, Ralph.
    I have discussed with Kyle at Wicked Edge, them adding a “Gen 3 Pro Pack” to the current model line.  It may be in the future.  It would only need a few more accessory items to be outfitted as comprehensively as the Pro Pack 3.  Since it comes with the hard case it would be easy enough to ship everything.
    #49855
    That edge turned out nicely.
    #49856
    Pinkfloyd
    • Topics: 22
    Excellent job on the Benchmade!
    #49863
    Kevin
    Looks great…what lapping strips did you use?
    #49866
    Ralph
    I used the 6 micron Diamond Lapping strip, and then the two strops that come in the Pro Pack III.
    #49867
    I am pleased to see there’s no scratches on the Benchmade’s scales.  That’s usually where we screw up as newbies.  When you’re doing a high-end knife, cover everything with painter’s tape.  Especially the sides of the blade.
    If you’re thinking about buying other lapping films, consider buying additional handles so you don’t have to strip off films which are still good.  They last a pretty long time.  I wash mine with a battery-powered scrubber and alcohol about every other knife and I’m getting about thirty sharpenings out of them.
    BTW, great looking edge.
    #49869
    I am pleased to see there’s no scratches on the Benchmade’s scales. That’s usually where we screw up as newbies. When you’re doing a high-end knife, cover everything with painter’s tape. Especially the sides of the blade. If you’re thinking about buying other lapping films, consider buying additional handles so you don’t have to strip off films which are still good. They last a pretty long time. I wash mine with a battery-powered scrubber and alcohol about every other knife and I’m getting about thirty sharpenings out of them. BTW, great looking edge.
    Thirty knives per strip of film is the best lifespan of use I’ve seen anyone report.
    #49883
    Jeff
    Your blade looks great.  The many different films, strops, compounds, makes creating mirrored bevels fairly easy.  I have found in my experience for a pocket knife that I prefer a little toothier edge for actual usage.  If I do end up polishing the bevel, I typically add a lower grit micro bevel a few degrees steeper.  It will no longer whittle hair then, but I find it will keep a usable working edge longer.
    #49884
    Jeff, I am asking for clarification of your terminology a “few degrees steeper”.   I understand this to mean an angle less than the bevel sharpened angle.  For instance if your edc bevel was sharpened to 20º are you saying you apply your micro-bevel at 17 or 18º, a few degrees steeper, to give your very polished bevel a toothier feel.
    A steeper, or as I understand your terminology, shallower angle,  then the original sharpening angle will orient the sharpening stones to contact the bevel at the lower portion of the polished bevel or even below the original bevel and possibly behind or below the bevel at the shoulders.
    To apply a micro bevel to impart a toothier feel to the apex, are you meaning to say you would want to set the angle a few degrees wider, less steep or more obtuse for the micro-bevel to be applied to the very edge of the knife edge, that is to the apex?  This would add a very tiny toothy bevel on top of the shiny polished beveled edge.
    I may be talking semantics but in the case it can mean the total opposites.
    #49885
    Jeff
    Marc I can see where what I stated could be confusing.  Steeper is maybe a bad word choice.  As an example.  My “garage” knife is a Spyderco Manix.  It is just their standard is CPM SV30 version.
    I set the bevel at 15 dps and progress through the stones down to 1.5 micron lapping film.  I sometimes even strop if I want to bring the shine up on the bevel.  Then I put on a micro bevel at 18dps with the 1000 grit diamond stones.  Just a very few light passes on each side.  This is my preference in a “work knife” for lack of a better description.  As it dulls over time it is a quick touch up just on the micro bevel again with the 1000 grit at 18dps.  After a couple of usage and touch up cycles, then I will go through the full progression on the main bevel again.
    I think this explains myself better.
    I only go this route on harder usage work knives.  Kitchen knives I just stick with a primary bevel only.  The angle is dependent on the quality of steel and style of blade.
    #49886
    Thanks Jim for your clarification.
    You might sometimes want to try stropping your 18º 1000 grit micro bevel at 16º or 16.5º, as a final step.  You may find you’ll get the toothyness and durability you desire and the smoothness to still slice paper cleanly, with addition of stropping.
    #49889
    Ralph
    I sharpened up a couple of more pocket knives. My old Kershaw, and my work knife, the Buck. I got the mirror polish on both of them with the same lapping film I used for the first knife. I don’t know if I will get 30 knives with that one lapping strip, I figured maybe 5, if I’m lucky. I’m not into the toothy edge, but thanks for the suggestions. I’m running out of my personal knives to sharpen, so pretty soon, I will have to start sharpening my friends knives, and that is when the fun starts. Most people have no idea how sharp you can get a knife, and when you sharpen one of their old knives, they can’t believe how sharp it is.
    #49916
    Organic:
    When I get pretty far along in the life of the films, they look pretty ratty from all the nicks and slices, but they’re still working.  Usually, that’s where I strip ’em off and start over, but lately I’ve been deliberately trying to push them to their limits, and I’m not seeing an appreciable loss of performance.  In fact, I can’t remember the last time I replaced a film strip for any reason other than surface damage.
    I have seen films which were clearly showing loss of abrasives.  It looks like a shiny patch, when compared to the satin look of the remainder of the patch.  Maybe it was caused by a cleaning chemical, especially lacquer thinner, which I use a lot.  It will wipe the mylar film free of any attached abrasive with a single swipe.  Oopsie!  In any case, the life span has improved when I switched to a regular cleaning routine.
    Like they say on the stock market ads – past performance is no assurance of future results.  But I’m suggesting that the life span can be extended with special care taken.  Black discoloring should not be considered a sign indicating end of useful life.  Aggressive scrubbing with a non-metallic brush can remove a majority of the crud clogging up the typical film abrasive and give it more life.
    #50048
    Ralph
    I sharpened my Sterling Silver Buck knife and was trying to show the mirror edge I put on it, but decided to show the mirror finish on the Sterling Silver scales instead. They look fantastic, just as long as you don’t handle the knife. They are a finger print magnet. So what’s the deal on the Sterling Silver Buck knife? Apparently they are super rare. Most of them where engraved because of the finger print problem. From doing google searches, this is the only one I found that hasn’t been engraved yet. I got lucky and found it at a pawn shop a couple of years ago with the original box, and bought it on the spot before doing any research on it. The Wicked Edge put a wicked edge on it as usual.
