Experiences with 3micron diamond stone
Recent Forums Main Forum Techniques and Sharpening Strategies Abrasives Experiences with 3micron diamond stone
  • #23486
    Alfredo
    Anybody has tried the 3microns diamond stones?
    Comments? Experiences? Any input is welcome. :woohoo:
    #23488
    Lance Waller
    • Topics: 23
    +1^^^^^
    #23489
    Aaron kimpton
    • Topics: 8
    I would be interested also. It seems like this should come after the first set of ceramics?
    #23514
    blacksheep25
    #31927
    dulledge
    • Topics: 12
    Unfortunately link in previous post is broken. Page not found.
    Did anybody have experience with 3 Micron Diamond Stone ? In which scenarios do you use it? How long was the break in period? What is special about this stone that makes it different from diamond lapping film or strops?
    #31931
    No experience with the stones, but here’s the link…
    Confused by 3 micron diamond stones
    #31932
    That gessweincanada.com chart matches the one I got from Advancedabrasives.com almost exactly.  It lists 15 micron as being equivalent to 1200 grit and 9 micron as being equivalent to 1800 grit.  When I switched to film, the 15/9 films effectively replaced the 1200/1600 ceramics.  The scratch patterns look extremely similar and I feel that the film is more consistent.
    There’s been some discussion (see cwbx’s link Confused by 3 micron diamond stones) about bad scratches with the 3 mu diamond stones.  I don’t have a pair, but I’ve had some experience with breaking in a set of 800/1000’s which revealed some freakish clusters of grit standing proud of the surface.  The clusters were oriented parallel to the stone, so they resisted normal break-in and continued to produce really bad scratches well beyond the normal break-in period.  It was when it badly chipped my ZDP Delica that I finally did an inspection and found the offending clusters.  I clamped up a short section of plate glass and worked the edge for maybe ten or twenty strokes at normal pressures and the clusters were gone.  I imagine the possibility exists for similar problem with the 3 micron stones.
