Double Riser Block Mod
Recent › Forums › Main Forum › Sharpener and Accessory Maintenance › MODS › Double Riser Block Mod
- This topic has 26 replies, 8 voices, and was last updated 03/10/2015 at 12:56 pm by
CliffCurry.
03/07/2015 at 12:33 pm #24172
Thx Tom, it’s to early to say for sure but I’m feeling like I may have stumbled onto something…
When the angle adjustment bar is placed up front like this it seems to handle several issues at once and possible removes the need for a double spacer block(possibly the LAA as well?), and places the rods home position when vertical more out over the center mass of the blade eliminating the need to angle the knife down so much when mounting at the back end like on ffg knives etc.
Of course increased blade play on larger knives may be an issue, but my first impression is favorable.
Agreed that the new clamp could open up even more new ways to use the WEPS!
03/07/2015 at 12:42 pm #24173What about a base equipped with pre-drilled (x,y) holes laid out in a a grid like fashion?…
Would you even need the base?…
Possibly just the riser block to get the required clearance?This way one could position the crossbar relative to the center mass of the blade.
03/07/2015 at 12:53 pm #24174Tomorrow if I have time I am going to do a comparison with all the different possibilities I can think of in different configurations.
The goal being to reel it back in a bit and see what’s the simplest way to get the widest range of options for all different type of knifes.
It’s been an exciting day I must say!
03/07/2015 at 1:41 pm #24176Tomorrow if I have time I am going to do a comparison with all the different possibilities I can think of in different configurations.
Cool!
03/08/2015 at 12:17 am #24184I like that alot, I have been thinking of a second set of clamps to go with the low angle. But specifically long flexible knives. make the mounting clamp section a little wider than the base. say 4 inches.
03/08/2015 at 2:44 pm #24196Definitely need a 3rd arm support clamp for longer flexible knives regardless how much you “Inspector Gadget” your WEPS…unless you like working one side at a time while bracing with the other.
As it happens a buddy recently asked me to sharpen his super old Mac kitchen knife, chipped, pitted, blunted, never sharpened…you get the idea. So I decided to give it a shot with the new setup…
First I thinned the blade at 3.5dps to remove as much previous damage as possible, then placed a 1000 grit edge bevel at 14dps….now I really wish I would have taken a before shot but didnt think of it until too late.
Keeping in mind Ive never thinned a blade before, and that this setup is a new deal, I was really happy with the results. Before applying the final edge bevel I also took it lightly to the buffing wheel. I think my buddy will be surprised.
03/08/2015 at 10:31 pm #24207Great job, Cliff!
03/09/2015 at 9:05 am #24221Precision thinning; that’s impressive!
03/09/2015 at 8:07 pm #24223More great ideas from Cliff…
Cliff, how long does it take to thin such a blade by hand with your setup? I think some guys have done it freehand, but I always thought it was a very tedious process and best done with a belt sander & fixture.
That plastic sleeve you’ve added to your rods – it reduces the effective length of your stones (you can’t use the top inch and a half or so). I’ve even cut down the length of my ball joint connectors to gain more length. As there is almost zero tensile force applied to the rod, I cut them down to about two threads.
03/10/2015 at 12:39 am #24228Thx Tom,
I think the time involved will ofcourse depend on how hard the steel is and how much you are removing. I have another crazy idea to mount a slightly larger courser stone to a paddle for re-profiling work, maybe something like 2″ wide by 1/4″ thick? Any grit/stone suggestions for reprofiling?
This practice job here didnt take long, maybe 1/2hr, but didnt remove a ton either. Just cleaned up the years of poor sharpening that had left it rounded over to a blunt edge.
Sharp eye on the plastic sleeve, your right, it is inhibiting full range. I had it for use with the LAA/Tormek “high rise” configuration and dont need it here as set up. Nice to have all the options.
03/10/2015 at 11:59 am #24237Very very nice Cliff. I’m curious to see a pic of your knife after thinning. (I assume the black stuff on the blade is a Sharpie line?)
03/10/2015 at 12:56 pm #24238Thx Mark & to everyone for the positive feedback on this. It’s very encouraging to hear when your not really sure if what you’re doing is gonna work out or if you’re doing it the “right way”.
It’s a fine line between risk taker & crackpot. :silly:
The 3rd photo of knife in jig does show thick sharpie being used as reference, and honestly I didn’t know what to expect & was concerned about keeping it even. Turns out the process was comfortably similar to doing a normal edge bevel thank goodness.
The 1st & 2nd photos show the 3.5 degree bevel with 14dps edge bevel approx .5mm high. The knife was on the thin side & I flexible to begin with. Another reason I chose to just remove the damage towards the apex while keeping some strength.
2 more things are needed to really get playing around thinning & reprofiling kitchen & ffg blades….
The first is the ram clamp, which digging thru older posts it looks like you have? Does yours have a 1″ ball or the 9/16th? After debate I ordered a 1″ ball setup from Amazon yesterday.
… And the final thing is a small benchstone approx 2″x 8″x 1/4″ that I can attach to a paddle. Maybe something in the 400grit range? I’ve seen & read info on re profiling but didn’t retain much because it wasn’t pertinent at the time.
By far the most fun I’ve had in YEARS trying & learning new things!!!
