DMT 3 micron stone
Recent Forums Main Forum Product Announcements DMT 3 micron stone
Viewing 10 posts - 46 through 55 (of 55 total)
  • #13709
    Phil Pasteur
    • Topics: 10
    I have a similar situation… no place to put the thing in use… or to store it when not in use.
    #13713
    Russ Read
    A little off topic, but could you share a bit about your microscope setup and how you are getting the images?
    #13714
    Mikedoh
    Welcome
    Clay has a microscope capable of 2000x magnification. How he sets it up, I do not know.
    #13725
    Welcome to the forum.
    Here’s an older thread on the microscope when he first got it you might find interesting… 2000x Microscope.
    #13730
    The scope has a built in 10MP camera that connects to the computer via USB. All the USB microscopes have their own software for processing the images, making measurements etc…
    #13733
    Leo Barr
    • Topics: 26
    Seki Cut double bevel camping deba
    I like the stand you have for your microscope I have the Veho 400x which is more of a toy and takes a bit of setting up although I guess in the vice clamp of the WE would be easier I am mounting the blades on bits of specially cut battening at the moment .
    Still the Veho is good enough for the moment !
    #13736
    A lot of people do really well with the Veho scopes and they make a great, affordable solution to help visualize the effects of technique and tools. I’ve found modeling clay to be a great aid in positioning knives for photography and microscopy. You put a little lump of clay underneath the parts that need support, usually a little more than needed and then press down on the knife to create a stable platform. Usually you get a nice imprint from details in the blade/handle that make it easy to re-position the knife to see the same area again at the same angle. That said, the stand for the Dino-Lite scopes is really good and definitely worth the money. The fine height adjustment makes focusing pretty easy.
    #13998
    Ken Buzbee
    • Topics: 14
    Hey Clay, any ETA on these?
    Thanks,
    Ken
    #14012
    Eamon Mc Gowan
    Thanks,
    Ken
    +1
    #15154
    Leo Barr
    • Topics: 26
    Surly ceramic stones will not sharpen ceramic knives or am I misguided in my thoughts I was under the impression only diamonds will do .
    I would like to see a combo of 1200 & 3 micron diamonds I think that would be more than adequate unless one wants to sharpen a ceramic straight razor ; I just want to be able to do ceramic knives I think 3 micron is fine enough that is finer by more than double than the diamond tape Edge Pro do which is 3000 grit they have a 1200 grit superfine diamond stone to precede the diamond tape .
    The DMT equivalent stones are Extra Fine 1200 9 micron & Extra extra fine 8000 3 micron which is a perfect combo that I have used on DMT benchstones to do one ceramic knife .
