I got my WE Pro Pack I this week and I’ve been practicing on a bunch of old, insanely dull steak knives. My first results were pretty terrible, but my last couple have been much better.
Last night I finally got my USB microscope to really see what was going on, and I spent almost 2 hours on this knife. First I ground in a new 20 degree bevel on my worksharp @ 80 grit because the edge was completely trashed and I had to remove… a lot… of steel. Then I started with 100 and progressed 200->400->600->800->1000->5µm strop->3.5µm strop. At each step I verified (to the best of this cheap microscopes ability) that I got all the previous scratches out.
I think I’m not using enough pressure when stropping, but I also think I need a lot more break-in time. This is maybe the 6th knife I’ve done. It’s sharp, but it does snag on paper. Not nearly as sharp as I can get something on the worksharp yet, but I got this because I now own a number of knives I straight up can’t put in that machine (and I don’t trust myself enough on a slack belt on my grinder for expensive knives).
Does this look like a reasonable edge for a new setup that’s only sharpened a handful of knives? How many more “cheap” ones should I expect to do before this is fine enough for a good knife? Any advice is greatly appreciated, thanks!
