Bevel angles
Recent › Forums › Main Forum › Techniques and Sharpening Strategies › Bevel angles
- This topic has 8 replies, 5 voices, and was last updated 08/19/2014 at 12:33 am by
JS.
08/15/2014 at 2:34 am #19920
Hi,guys,
After reading some posts in here, I have noted that my Spyderco Endura 4 has two ver different bevels, the right bevel is much larger then the left one, almost twice the size.
How would you advise I correct this, just work on the smallest bevel in order to correct it and make them both the same?
Thanks for your help guys.
Steve
08/15/2014 at 3:04 am #19923There’s a few issues that could be going on here… If you have never sharpened it before then this was done at the factory, which I believe is done by hand on a belt sander.
So either they:
– removed too much metal from one side and made them uneven
– they lowered the angle on the wider sideYou can fix it by:
– Making sure that the angle on either side of your edge is uniform
– Removing more metal from the shorter side to make them equal.Hope this helps, keep us posted!
08/15/2014 at 10:32 am #19926Just a quick bit to add…
I have a Spyderco Delica which came with a 17 degree bevel on one side and 24 on the other, so it’s not unheard of. I got it back to 20/20 by changing the angle a little each time for the first four or five sharpenings.
But you should be advised that Spyderco’s full-flat-grind causes problems in clamping them in the vise and this comes up at least once a month on this forum. FFG knives will not clamp securely in the normal manner. They’ll lean to one side or the other, or move left-right-left as you try to sharpen them since they’re only held right at the spine. You need to either make sure your blade is actually mounted with its axis vertical, using shims or padding, or clamp the blade flat to the fixed (left) jaw and kick the right jaw out at the bottom so that it clamps flat on the other face at the top. When you do this, you need to account for the left-hand lean angle in your left and right rod settings. With my Delica, the total angle between the two faces is 3.5 degrees, so the blade leans 1.75 degrees to the left. I set the left rod to 18.25 degree and the right one to 21.75 degrees for a total included bevel angle of 40.
If you’re clamping flat of the left side, the outer face of the right hand jaw, instead of showing the normal (vertical) angle of about 13 degrees, should read 13 plus the total face angle of your blade (3.5 degrees in the case of my Delica) for a clamped angle of at least 16.5 degrees. This will tell you that you’re actually clamped flat and securely on the right hand jaw. Does that make sense to you?
Oh, and line your vise with a piece of tape or something to keep the jaws from scratching the face of your nice knife. I use a little square of the blue Scott Shop Towels. But I learned the hard way. My Delica shows the scars.
08/15/2014 at 10:37 am #19927Cheers thank for you help guys, much appreciated.
Steve.
08/15/2014 at 12:17 pm #19929I got it back to 20/20 by changing the angle a little each time for the first four or five sharpenings.
I was going to say that it’s a waste of blade life unless it’s causing your problem while cutting, so I like TCMEYER’s solution to adjust it over several sharpenings.
Also, they have asymmetrical grinds, which are slightly different that chisel/zero grinds; you could think of this Strider SLCC Asymmetrical grind as a “partial” chisel/zero grind.
http://www.monkeyedge.com/Strider-Knives-Custom-Mick-Strider-Custom-Coated-p/sk1039.htm
08/15/2014 at 1:16 pm #19930Does different bevel angles affect and lower blade sharpness and Also the edge durability for lasting Long ?
Cheers guys
Steve
08/15/2014 at 4:11 pm #19932Just a quick bit to add…
great ideas here! or you can do this as one last option… quick and easy.
08/15/2014 at 4:12 pm #19933Does different bevel angles affect and lower blade sharpness and Also the edge durability for lasting Long ?
Cheers guys
Steve
not at all… the inclusive angle is what matters.
08/19/2014 at 12:33 am #20016Check out my post in this thread for a simple way to evenly sharpen FFG blades.
