Accessory for avoiding strops cross-contamination?
Recent Forums Main Forum Suggestion Box Accessory for avoiding strops cross-contamination?
Viewing 15 posts - 1 through 15 (of 59 total)
  • #6294
    Aleksei Dyachkov
    I’ve read the forum & the manual and it’s highly suggested that strops should be kept separately etc to prevent cross-contamination.
    I think it could be a good idea to make additional cover made form plastic.
    I’ve attached a sketch render to show the concept.
    It just covers one side & snaps on the edges. Color-coded to prevent using it on wrong side. The hole on the side can be used to tie two pieces together & enables to store strops/stones by hanging ’em on a hook or something.
    #6297
    Nice idea, beautiful rendering! Thank you for sharing it. Did you make your sketch to the specs of the handles and strops?
    #6298
    Aleksei Dyachkov
    Thank You.
    I didn’t use specs, It’s just a 10 minute sketch =).
    I can measure sizes & make it “fit” , but the model itself will be of no use, because it’s not made in CAD, just ordinary 3D software. It has option to export to DXF file to use with AutoCAD or other CAD application, but i’m not quite sure if it’ll work fine,
    #6304
    Geocyclist
    • Topics: 25
    I really like this. It solves the problem of cross contamination, but it would also work for all stones. I made of soft rubber material it would protect stones from shock and chipping.
    Further more, you could leave 1 side on and have a clean, grippy surface to hold.
    Nice work.
    #6322
    Will you send me the DXF file? If so, I’ll see what I can do with it.
    Thank You.
    I can measure sizes & make it “fit” , but the model itself will be of no use, because it’s not made in CAD, just ordinary 3D software. It has option to export to DXF file to use with AutoCAD or other CAD application, but i’m not quite sure if it’ll work fine,[/quote]
    #6337
    Dennis Gocong
    Yea, more accessories to spend my money on!
    #6338
    Dennis Gocong
    Great idea, Aleksei…..and excellent renderings too!
    #6497
    Aleksei Dyachkov
    Done.
    Sorry for delay.
    #6498
    Aleksei Dyachkov
    Thanks.
    If mass-produced, they should be cheap as dirt — the mould is expensive, the plastic isn’t.
    #11253
    Mikedoh
    Wondering if there are any updates re plastic strop covers?
    #11256
    Good question. I’ve mentioned it to our factory and it’s easy enough to do. I need to find a good draftsman to make the drawings to send off.
    #11257
    These would be great for the leather strops carrying them in the new case. 🙂
    #11262
    Eamon Mc Gowan
    I would buy those in a heart beat! Mine are kept in a zip lock bags right now. Those little case would be great!!
    #11264
    James Bare
    • Topics: 5
    I would definitely get some to cover my strops as well instead of a plastic bag
    #11265
    Aleksei Dyachkov
    I’ve sent to you original 3d-model a while ago. Could you make anything out of it ?
