1500 knives later…
Recent Forums Main Forum Techniques and Sharpening Strategies Abrasives 1500 knives later…
  • #29103
    Since I got the WEPS about 3-4 years ago I have kept my old stones once they were worn out in case I ever needed the paddles… well tonight I finally removed off all of the stones from the paddles! the 1500 is a guestimate… :blink: :silly:
    When I was taking this one off check out what I found! This was very interesting!
    Definitely not knocking WE… I’m getting about 400-500 knives off of each set of stones. I have tried DMT and Atoma plates and neither is as durable as the stock WE diamonds. Nowhere close.
    Now I’ve got me some new stones to break in!! B)
    #29104
    CliffCurry
    • Topics: 42
    Thats absolutely amazing!!!
    #29106
    Looks like there was some speck of corrosion that was plated over. Just like rust spreads under the paint of your old Chevy.
    I see three sets of 800/1000’s in your first photo. I think I do under 100 knives per year. So far, I’ve had one 400 and one 800 wear out on me.
    That’s a lot of effort to remove all those platens from that godawful tape. Did you use heat?
    #29108
    Well I used heat on a few of them to see if it helped and it did, but most of them just took a little work and they popped right off! The tape wasn’t bad…. It would just roll up in a ball with your thumb.
    I don’t know what happened to my extra 400/600 paddles. I know I’ve used more than one set over the years!
    #29109
    Congratulations, Josh.
    Tom, 65 degrees C in the dishwasher. And you can remove your stones B)
    #29110
    Now that you have all the empty paddles what can you do with them? Is there a source for replacement diamond plates or replacement ceramic or wet stones that are cut to paddle size?
    #29111
    Geocyclist
    • Topics: 25
    Congratulations.
    What percent do you think were re-profile vs. touch ups to knives already sharpened once on WE?
    #29112
    Very helpful tip! Sounds like you have done the same thing 😉
    Well there are a ton of things you COULD do w/ them, hehe. not sure what I will do w/ these yet.
    You could get any number of waterstones you may be interested in, say a line of the shapton pro series, but get them in the large block. Then cut them up on a tile saw, mount them to aluminum bases, and then to the WEPS paddles and sell the rest. This is just one application though! You could also play around w/ different strop bases: balsa, leather, nano cloth, etc.
    Congratulations.
    Most of the heavy reprofile work I do on a belt sander, then I simply microbevel w/ my WEPS at 19-20 dps w/ the 800/1k’s. But whenever I mirror an edge or match the existing angle I use the full progression. If I had to guess I would say that the 600-1k’s all have about the same wear on them, and then the lower grits (esp. the 100’s) have a ton of wear from hours reprofiling. Shoot, I reprofiled an Al Mar fixed blade to 10 dps by hand and that took me about 2.5 hrs per side – just reprofiling w/ the 100’s! So as you can imagine that takes life off of them. I don’t normally touch up ones already sharpened on the WEPS except for my own. Most of my customers have some sort of maintenance devise like the sharpmaker or stropping.
    #29133
    developer (ChrisB)
    • Topics: 53
    Shoot…. I’ve done about 30 knives and the diamonds of my 100 grit stone are peeling back on the edge.
    #29134
    Very strange… I’ve went through at least 2-3 sets of 100/200 grits and never had that issue, I may have on a 400-600 at one point, can’t remember. I know a different issue I had w/ my stones seemed like some cross contamination during the diamond plating process and you could feel larger diamonds in the surface of my 1k’s – Wicked Edge replaced immediately w/ no issues whatsoever. Sounds like you need to make a phone call :side: 😉
    #29174
    Call us: 877-616-9911. We’ll get you squared away ASAP.
    #29175
    developer (ChrisB)
    • Topics: 53
    Just called and all I can say is WOW! I have NEVER had such a smoothe customer service experience! Please tell the gentleman (can’t remember his name) that took my call that he was top notch!!!!!
    I love this company!
