I know I’ve read this before and I can remember a comment from Organic that the heel and the tip are areas that are harder to work or need more attention. And thats just what I’m finding.
With most of the last knives I’ve sharpened in that I usually have to drop down a few stone grits and work the heel and tip area again. I think this (at least with my newbie technique) is because the stroke that starts at the heel is an upward motion leaving heavier vertical scratch marks near the heel whereas for the rest of the blade I can use a very light side to side scrubbing motion which helps in removing the previous grit’s scratches when used with some of my final strokes. But the bolster of the knife stops me from doing this at the heel area.
And the tip usually causes me extra effort . . . for one to be careful not to roll off the tip with my ending strokes or I can round the tip which is not what I want. Sometimes since some blades are so short or flexible I use a small block of wood to prevent rolling off the tip. But it always seems to be the area on the very edge of the tip (near the spine) that I can’t reach removing that last bit of marker unless I just keep working and re-profiling that tip until the markers gone. I should be able to have the stones hit all the blade bevel area in the same stroke. I’ve read Marc’s sweet spot sticky several times and still feel I’m doing a wrong blade placement in the vice to have to continue to work harder on the tip area. It is a very slight area of marker that is left and usually I have to see it with my 10x lighted scope so I know I’m not apexing that area or drawing a flat bevel across the entire blade length.
I can understand having to re-position a “long” kitchen knife or do it in two parts, but these are only 3.5 or less than 4 inch folding knife blades I’m working. To compensate the marker still on the very tip, I’ve tried tilting the tip slightly down in the jaws while keeping the blade still contacting the front peg of the depth key. This seems to work, but it can give me a second bevel right at the tip or cause the bevel along the length of the blade to be wider near the tip area. Maybe I should be “raising” the tip slightly instead of lowering it? I’m trying to keep the blade within the curving arch of the stone travel and centered with the rod attachment points.
I’ve also read in the threads another way to compensate for the tip not being worked enough is to reposition the blade in the jaws slightly back towards my body.
Please give me some tips as to my probable incorrect technique, because I don’t want to work the tip anymore than needed so as not to remove too much metal which over sharpening sessions I might be weakening the knife tip.
