What grit/micron should I have mirror polish?
Here is my lineup of available paddles…
100/200, 400/600, 800/1000, 1200/1600 ceramics, 3.5/5 micron paste on leather strops, and 3.5/5 micron paste on balsa strops.
I also have 1 and .25 micron sprays but I need to get another leather strop set to use it on.
I have done a few knives since getting the WEPS. I have gotten some pretty good results edge wise. But I just can’t get the perfect mirror. I always have some residual hazing no matter how long I stay at each step or how I vary the direction. If I had a better macro lense I would take a pic but I dont. Just suffice to say the mirror is impressive to most folks but I know I can do better.
So how low do I need to go to get a perfect mirror finish? Or do I need to maybe work longer at some of the later steps? I thought I did enough but maybe not.
From my experience (not with the WEPS yet)it has’nt become a real nice mirror finish till I got down to the 1u range.
Depending on how many knives you’ve sharpened, your stones may still be breaking in. During that process, they’ll cut deeper scratches that will take longer to remove with the fine stones. You can spend more time with the ceramics and use a little soapy water with them and they’ll polish much more quickly.
I am getting sort of a mirror finish with the 3.5 micron strops. Of course until you wear off the excess compound the strop just slides on compound, so that takes some time. I am also still seeing some remaining scratches from prior grits, so I am still in the process of wearing in the diamonds. I am about 15 or so knives in.
I wonder if you can get rid of all the scratches with just the stones and then stropping?
Seems like the really polished edges are comeing from the water stones, and then under high magnification there still seems to be scratches.
Lucky
[quote quote=“gofly” post=930]I wonder if you can get rid of all the scratches with just the stones and then stropping?
Lucky[/quote]
Even with the finest Shaptons or Choseras, scratches are visible under the microscope. They should be very fine and uniform. Stropping helps to diminish them further, though they never go away completely. Once you think they’re gone, you can just up the magnification and see the finer ones. Still, you can get pretty far with the stock stones and strops. Here is a knife that I sharpened with stock Wicked Edge stones and then stropped to .25 microns:
Here is a cheap knife, I got for free with the purchase of a holster, and it is a real POS. I spent about 20 mins total from reprofile to strop, so with no time, on a crap knife, and an awful camera, here are the results.
I just purchased the WES a few weeks ago and have the same problem with getting a mirror look.
The smallest grit stones I have are the 800/1000 then the 5 and 3.5 strops.
How do you know when to go to the next highest grit. because my edge is not even close to mirror.
now it is sharp but dull and scratchy looking. I spent 30mins working on this.
Should the 1000 grit leave a smooth not polished finished…???
Is there a step by step instruction
on going from one grit to another?
[attachment:3]spdy blade.jpg[/attachment]
What stones and/or strops did you use?
This is an interesting question and one that I was discussing with Steven recently. More on that in a bit.
I have never gotten to what I would consider any level of mirror edge with the WEPS diamond stones. The scratches are simply too deep and the edge scatters light rather than reflecting it back in a single direction. I have never used the WEPS ceramic stones (mostly because I could never get them). Lots have people have said that they could get a mirror edge with them. I would think that you could with the new microfine ceramics too, but it would require a bunch of strokes.
The thing that I started off with here was the conversation that I was having on trying to measure the amount of mirror in what people call a mirror edge. Some people say that a 1000 grit Chosera stone give a mirror edge. There was a video posted here where a member created what he called a mirror edge with the stock stones and various grades of sandpaper and lapping film.
I find that I get a nice looking edge that reflects well after the 2K Choseras, but it gets visibly better with higher grits. After the 10K it is really starting to reflect. After each grit of stroping compound it gets better. I end with 0.025 micron on nanocloth and it is real shiny. So, what is the difference between my 0.025 polish mirror and the folks that get a mirror at 1000 grit?
More in a bit.
Ok Tom in his excellent series on using the Choseras and Shaptons talks about something called a “Critical Leap” in a progression. He defines this as the point (and I am paraphrasing) in a progression where the polish goes from being shiny to the eye to the point where it is shiny in the microscope. For the Choseras he says that is at the 10K level, from memory now, he says that it is at either the 15K or 30K level with the Shapton stones.
Now I wanted to see if I could quantify the difference that I see going from the 10K stone to the 0.025 micron spray on nanocloth. What I found out is that there are devices sold as optical reflectometers that would give the answer. Unfortuanately they are real expensive. But the key thing to remember about them is that their primary function is to measure surface roughness. The smoother the surface for any given material, the more it reflects… and the more mirror like it becomes.
Keeping this in mind it is easy to see that the higher grit you use, the smoother the surface, and the more mirror like your edge becomes.
Someone asked about getting a real reflective edge but still having some haze. Another thing I found out in researching this is that any given material has a maximum amount of reflectivity, even with a “perfectly” polished surface. Clay mentioned using more magnification will slways show some abrasive pattern, wekk what if we could use and abrasive that left no scratches… that would be a perfect polish. At that point most stainless steel would reflect 65% of the light falling on them. Manipulating the angle of the light that you use to view will likely always result in you seeing a less than perfect reflection, no matter what you polish with.
This 65% is nothing close to what a good telescope mirror will do… in the high 90s.. 96 to 98%. No matter what you do to steel, you will not get there.
So what am I saying? First, a mirror edge is a relative term. I found that some places doing inspection for levels of polish ahd to get humans out of the loop because they were too subjective. Bottom line is, if you think that you have a mirror edge at 1200 or 1600, take it to 0.025 microns, you will see a difference, but you will not have a true mirror edge!
Second, if you want an edge that comes close to the maximum reflectivity for the steel that you are using, it takes very fine abrasives. Unfortunately the 1000 grit diamonds will not get you there.
I guess this brings up a question. What do you really want to do? If it is to get a great working edge that is very sharp and will work great for most cutting tasks, the 1000 grit diamonds will get you that.
If your goal is “pretty” resign yourself to pursuing ever finer grits.
Hope this helps, and I can quote sources for anyone interested.
[quote quote=“RonRobichaux” post=4250]I just purchased the WES a few weeks ago and have the same problem with getting a mirror look.
[attachment:3]spdy blade.jpg[/attachment][/quote]
Hi Ron,
Welcome to the forums! And congratulations with your WEPS.
I normally get a mirror edge after the 1600 grit ceramics (use them with some water!) and the 5K Choseras. Obviously, if you go any further, the mirror edges only get better.
These mirror edges are also greatly enhanced by stropping with some Wicked Edge paste on leather.
Like Philip, I have not seen a mirror edge after the use of the diamond stones only, although you might be able to get one if you strop with a Wicked Edge paste on leather for a long time afterwards.
Success in obtaining your mirrors!
Couldn’t resist… for post # 100.
I added a bunch to the post I made just before Mark’s
4254.
I hope I wasn’t too wordy.. I hate typing
:slight_smile:
#4254.
:slight_smile:
The wavelength of visible light is between 0.38 and 0.74 microns.
http://en.wikipedia.org/wiki/Visible_light
Modern optical microscopes have a resolution limit of 0.2 microns (about 1/2 wavelength).
http://microscopyu.com/articles/optics/index.html
Telescope mirrors are accurate from about 1/8th to 1/20th wavelength, with the most common being around 1/10th wavelength. Although, they are often smoother than this.
So if you can get your scratches significantly below 0.2 microns then you should have a very good mirror finish. So my guess is if you can get scratches down to around 0.1 to 0.05 microns, it’ll be a superb mirror finish even under a microscope.
It is interesting to think about the above in relation to the size of abrasive particles. Although I have no idea how to go from particle-size to scratch-size (it’s too complicated; depends on hardness, shape, friability, pressure, binder, etc.).
Komitadjie’s Grand Unified Grit Chart as plotted by Mr. Wizard:
http://www.knifeforums.com/forums/showtopic.php?tid/904090/tp/7/
Sincerely,
–Lagrangian
Anthony,
Godd stuff.. in theory. Unfortunately you do not take into account the intrinsic reflectivity maximums for a given material. I will send some info tomorrow form one of the premier polishing companies in the world claiming a max of 65% reflectivity for “stainless steel”. Of course different limits for different formulations of steel.
In any case, folks using 1000 grit diamonds will not see a mirror finish. People percieving a “mirror” at the 1200/1600 grit level, have a reflective surface, but a ways to go to get to the reflectivity limits of steel. My post was because I was trying to explore how some people say they have a mirror at X grit and others at XXX grit, and what accounts for the difference.
According to Tom and he has photomicrographs at 400x, the 0.17 micron grit of the 10K chosera is where he saw significant reflectivity … at 400X that is as good as the empirical data that I have seen goes.
I will be intersted to see what can be done with Clays new microscope. I would love to see some sort of hard data that sorts one person’s mirror from another’s more highly polished mirror.
This is real interesting stuff.. as soon as we figure out that we can polish metal to the degree that we can rival optical mirrors… I can throw away a bunch of pyrex mirrors ground to 1/20 wave and optically coated for 96 to 98% reflectivity…
:slight_smile: (of course then you have to deal with coefficients of expansion and other obtuse issues. They did give up on speculum polished metal mirros a hundred years ago…
Of course, then we need to figure out who cares about reflectivity of an edge… sharp is what we want.. polish is just pretty…
Polished EdgeThis is the best I’ve been able to do so far and I’ve been able to repeat it several times: I haven’t had a chance to do it again and put it under the new scope (plus I’m still waiting for the 100x objective to come back from the manufacturer) but I’m pretty excited to check it out once I get back from VT.
10K Chosera - 800xI was able to do some measurements at 800x of a knife I sharpened up to the 10k Chosera stones. Check here for the full sized image:
For some reason, the measurements are really hard to read there, but they range from .89um to 1.51um. I only measured the major scratches. I’ll keep working on how to post the images so that the measurements are easy to read.
To add a bit to this… I sharpened a knife and repeated what you have… 1000 –> 5m –> 3.5m leather, and couldn’t get a mirror finish, even with quite a bit of time on the leather. So, probably not possible, at least not in a reasonable time. (Forgot to snap a photo).
I then went back to the 1000 and then went to the new MicroFine ceramic… coarse then fine for about 50 passes with each. (I haven’t lapped my stones). Then on to the 5m –> 3.5m leather for about 75 passes each, and got the start of a mirror finish (obviously without magnification)…
Still a bit of scratching, but considering how little time I spent, this would be at least a good start toward a finer/mirror finish, if that’s what you’re looking for.
I suppose that I am beating a real dead horse here, but
Shouldn’t we have some kind of definition of “mirror edge”
before we try tell people how to get one?
I just finished a Ken Onion Foresite, suposedly an initial production blade in (depending where you read) Acuto 440 or Acuto +.
I went through the diamonds form 100 grit. I reprofiled to 18 degrees, just to see how this steel would do.
After the 1000 diamonds the blade was plenty sharp, but pretty much a matte finish.
I sued the Chosera 800 grit for 100 strokes, still matte finish. I went to the 1000 grit Chosera stones for 100 strokes. Now I was getting something that was pretty reflective, but still not what I call a mirror edge.
I progressed through the 2K and 3K Chosera stones, now I could see detail in the reflection form the blade. At this point I would call it real darn shiny, but not a mirror. I think at this point well taken photos on a macro level would show clear text reflected.
I went to the 5K Chosera stones for 150 strokes. Now it was real shiny. Good enough given the angle of the reflection to make real impressive pictures with text reflecting off of the edge. Still if a light was shined pretty close to along the edge and the eye close to parallel to the blade, there was a bit of fog.
I went to the 10K choseras fro 150 strokes. Now we are getting close to a mirror. It is gleaming with incident light, but at at angle close to 180 degrees, still a bit foggy.
I went to a Naniwa 12K Superstone for 150 strokes. Now it is getting close to your bathroom mirror. The overhead light quite detailed in the edge, without picking the best angle.
I have a 15K Shapton set still to try, but I skipped that and went to strops with 6 micron, 3 micron (DMT paste) and then 1 micron and 0.5 micron diamond on leather. I don’t think that this changed the reflectivity much at all. I only did 100 strokes per grit. Just enough to refine the edge a bit and give a bit of convex grind to it. The knife is really scary sharp and glitters like freshly polished chrome.
So what is a mirror edge? Obviously to me, that is relative to the observer, the kind of steel and how much the edge is polished. The constant in the conversation is, finer grits make for a more polished/reflective edge. The more reflective the edge is, the more mirror like it is.
If you aren’t getting what you consider to be a mirror edge, use finer grits !!
As a direct answer to the OP, for my definition of a mirror edge, you need to get to the 5K Chosera level (or Shaptons, but according to Tom, who loves the Shaptons, they don’t polish as well). That is about 2.8 microns (2.94 for the Shaptons). You can definitely get there with pastes or 3M lapping films at the similar grit levels, but it will take much longer. There is just not as much abrasive involved in the pastes, sprays or films as the better stones.
I like to use the optics standard for mirror finish, which means that a surface is smooth enough to do high quality imaging, such as for a camera, telescope, or microscope.
Amateur telescope makers grind their own mirrors, and to test the quality of their polished mirrors, they use a laser-pointer test.
http://stellafane.org/tm/atm/polish/polish.html#Polished_Out
If the mirror is sufficiently polished, then all the reflected light obeys angle-of-incidence is equal to angle-of-reflection. (A fraction of the light is adsorbed of course, but that is irrelevant to our discussion.) This means that you should not be able to see any laser spot at all. This is because all of the laser light reflects away from your eye (or camera), which means, you can’t see it!
Unless of course, you are looking at it from the angle-of-reflection, in which case you are damaging your eye (or camera) with direct laser light.
In the picture above, the mirror is not polished out because you can see the front-surface reflection. This means that some light is scattering off in “random” directions from tiny residual scratches. Because light is scattered “randomly” by residual scratches, some of it is scattered into the camera, which is why we see it in the photo.
Once your scratches start going below half of an optical wavelength, you will be at or close to an optically smooth finish (ie: mirror surface). Loosely speaking, light cannot notice features which are much smaller than its wavelength. This is why astronomical telescopes are typically accurate to 1/10th wavelength. More accurate mirrors exist, but that is at the point of diminishing returns in terms of image quality. For astronomy a mirror that is accurate to 1/4th wavelength is considered to be the lowest quality that is still (somewhat) usable.
The optical standard(s) of mirror-finish are very high. Someday, I would like to attempt an optical quality mirror-finish on a knife edge for no reason other than my own amusement. :slight_smile:
In practice, being able to read fine-print text in the reflection of your knife bevel is, in my opinion, a good enough definition of mirror-finish. Say, your eye 6 inches away from the knife and the text 6 inches away from the knife. One might also require that the surface have no noticeable “haze”.
By the way, please remember:
(1) Do NOT look at a laser directly!
(2) Do NOT look at a directly reflected laser from a shiny surface. For example: windows, polished metal, etc.
(3) Do NOT look at laser light through any optics. Optical lenses and mirrors can focus laser light to the point where it will cause eye damage.
Doing any of the above can cause eye and/or camera damage. Even if the laser is a low-powered laser-pointer.
Sincerely,
–Lagrangian
P.S. The adsorbed light is not really relevant for our discussion in the following sense: Black obsidian (basically black glass) adsorbs a very large fraction of incident light (that’s why it is black). But black obsidian has been used as mirrors in ancient times because it can be polished to a shiny flat surface. Flat and shiny enough, that you can clearly see yourself in the reflection.
http://en.wikipedia.org/wiki/Mirror#History
Just as black glass can have a reflection, even materials with relatively high adsorption can be polished to a mirror finish. Steel is more than reflective enough to make a mirror. For example, many high-precision steel ball bearings have a mirror finish. Here is a company that does optical-polishing of steel to create steel mirrors and optics:
http://www.precision-metal-optics.com/stainless-steel-mirrors.htm
