[quote quote=“AnthonyYan” post=4346]I like to use the optics standard for mirror finish, which means that a surface is smooth enough to do high quality imaging, such as for a camera, telescope, or microscope.
Once your scratches start going below half of an optical wavelength, you will be at or close to an optically smooth finish (ie: mirror surface). Loosely speaking, light cannot notice features which are much smaller than its wavelength. This is why astronomical telescopes are typically accurate to 1/10th wavelength. More accurate mirrors exist, but that is at the point of diminishing returns in terms of image quality. For astronomy a mirror that is accurate to 1/4th wavelength is considered to be the lowest quality that is still (somewhat) usable.
In practice, being able to read fine-print text in the reflection of your knife bevel is, in my opinion, a good enough definition of mirror-finish. Say, your eye 6 inches away from the knife and the text 6 inches away from the knife. One might also require that the surface have no noticeable “haze”.[/quote]
“Visible light is approximately in the range of 0.4 to 0.7 microns (okay, if you are really picky, the 0.38 to 0.74 microns). If you want, that’s 400 to 700 nanometers, or 4000 to 7000 angstroms.”
Is a quote that is helpful from one of Anthony’s previous posts.
If we go with the half wavelength figure as indicating optical mirror quality we would have to polish to about 0.025 microns to get to this optical quality level. This assumes that the depth of the scratches we get are equal to the grit size, which is not always the case. Of course there is the additional polishing as the grit on the stones fractures and becomes smaller. We may get there with 0.1 micron abrasives as they break down… and with more time.
This site has an interesting chart:
http://www.warleypolishing.co.uk/technical/surface-finish-table-guide.php
They have two grades at the high end. Both claim a surface roughness figure of 0.5 microns. The difference is in the amount of reflectivity. It would seem from this that there is more to polishing than surface finish alone. There is the part that I call brightness. Maybe I can see a reflection enough to see print at 3 micron grit, but it is much brighter and better refined at 0.5 microns.
I like the 6 inches to the subject and 6 inches to the eye definition, because at least it is some kind of definition. Maybe we could refine it and state the font size that represents “fine-print”. Perhaps a number 4 point font? The one thing that is not there, and without sophisticated measuring equipment, is very subjective, is brightness of the image. I am not sure how we cover that one.
One thing for sure though, we never can get an optical quality mirror surface on our edges. The max reflectivity of typical stainless steels is about 65%. This does not come close to the 90%+ (some as high as 99.9% in dielectrically coated flat mirrors as in the case of a couple of the star diagonals that I use)in an optical mirror.
