Hi all, new user/owner here. I have the WE Commercial. I think I understand the concept of the unit and how everything is related to each other. You change one variable and the geometry of the other settings change as well. For example, the numbered angle settings are accurate when a blade is in the vise jaws and the edge of the blade is 5/8" from the top of the vise jaws.
Like many I have some 8 inch chefs knives that are tall from spine to edge, a few inches. So when you place the knife in the vise on the lower/bottom depth key setting, it is still about 1" from the top of the vise jaws to the top of the edge, which is more than the 5/8" height for the matched numbered angle settings.
So right out of the gate the only way to know the angle in this case is by using an angle gauge, correct? I noticed that if you don’t use the depth key and set the blade all the way down in to the bottom of the vise you get almost another 1/2 inch of depth and in my case this knife now is about 5/8" from the jaws to edge and the numbers would be accurate.
Is anyone sharpening without the depth key and using the 5/8" from vise to edge as the starting point?
Because if your method is to use a marker and then record the settings once you find the correct angle, the numbered angle settings on your unit become somewhat irrelevant, don’t they? Because it appears it will be different between each model as well.
As a noob I have just noticed that if I have the knife set in the vise and find the current angle using a sharpie marker and the stones, the numbered angle settings are not accurate and it’s more or less a reference point to remember on this particular unit.
If that makes sense…
Are you clamping without the depth gauge having the knife seated at the bottom of the vise? Thanks
