Hey all,
I’ve had my WE a couple of weeks now, during which time I’ve been going through the usual learning curve. My first success was with my S30V Paramilitary 2, which I was able to get a real nice edge on. My issue is the heel of the blade. While I was able to sharpen the rest of the blade like I wanted, the stones don’t reach into that little nook formed by the finger choil, so now there’s a little notch there. How do the rest of you handle this or is it just the function of the sharpener on this kind of blade?
Wow, 21 views and not one of you has experienced this?
Some folks have stated that they helped this situation by grinding off the plastic edges of the stones to be even with the diamond plates. For me, it was not worth the effort for such a small area.
I had the same problem and this is exactly what I did… Took it on my belt sander for a short bit no problem now
Those are your two main options. I suppose you could jury rig a solution but if this is a concern AND a regular occurrence I’d just remove the shoulders from the stones.
Ken
Thanks for the replies guys. It’s not a big deal, not big enough to grind the blocks down.
i had the same problem and it drove me NUTS. my solution not really cost effective. i went out and got the choseras. since they’re thicker they clear the choil on the para 2
Thanks Kyle. I’m not quite ready to go the Chosera route, but I’ll keep it in mind.
Clay has suggested that you can pull the plates and add a layer between them and the platen…
The layer being whatever you can cut and lay down to fit of the desired thickness.
Maybe grinding the plastic would be easier…
It doesn’t take much additional thickness. a credit card thickness of plastic would likely get you there. I just put up with the issue until I bought some Chosera stones…
I am real glad that I got them..!
I managed to work on that small corner by lifting the blade handle while on the WE. While doing this I was able to reach it.
good move..
Always more than one way to skin a cat.
You will change the angle slightly by doing that though…
Not really, the blade remained in the same position, the only thing I did was flex the handle upward to reach the actual blade tail.
I see, you unlocked the handle and moved it. Interesting, I never thought…having had the same issue myself, that moving the handle would give any extra clearance.
I have a few Paramilitary 2 knives. I will have to check it out. It really stopped being a problem since I have had thicker stones, but it would be nice to be able to do for those jobs that are OK with the stock WEPS diamonds and ceramics.
Say hey, Jose,
I’m not quite clear about what you’re suggesting. Are you changing the angle of the entire knife in the clamp? Since the stone is hitting the forward-most part of the finger choil, it’s not clear in my mind how that would work. If you could clarify, I’d appreciate it.
Thanks!
John
John,
No, I’m not changing the angle at all. While the knife is set in the clamp and locked, I just unlock the knife handle and lift it up until I got the necessary clearance to reach the edge tail. It is like closing your knife but this time it is already locked in the clamp ready to be sharpen.
Thanks Jose, I’ll give that a shot. The Para 2 is one of my favorite knives and the S30V takes an amazing edge, it’s just that last little bit that’s bugging me.
[quote quote=“FedWayJohn” post=10458]Say hey, Jose,
Thanks!
John[/quote]
You are right. I just checked a couple of my PM 2 knives. The edge of the handle hits the Ricasso, or choil… the transition from the full thickness of the blade near the pivot where it transitions to the blade grind and bevel… before the diamond plate can reach that transition… Anyway I don’t see where the handle position has anything to do with what I am seeing.
Jose, could you post pictures? Just to make sure we are talking about the same thing.
BTW this is the case with most of the Spyderco knives that I have sharpened.
Phil,
I will post some pictures as soon as I get back home. This week I’m traveling on business.
Phil,
I don’t have a Para 2 with me, I had one and sold it before I got the WE. Later on I had that issue with the Spyderco Ambitious and I solved it by lifting the handle as I expressed before. On the Para 2 you don’t have to lift the handle because it has enough clearance to reach the blade, but yes, the issue on how to reach that tail notch is a problem because the stones are to thin and the stone plastic edge is in the midle. Sorry about the confusion.
But if the edge is right into the handle as the Ambitious, that is how it worked for me.:ohmy:
