I cover my ball joints with thumbs from rubber kitchen dish gloves. I cust just a tiny slit (1/16") in the tip and pull it over the rod. This gives a very tight fit. I just cut the thumb/finger to length.
I found some nylon screws at Lowes to replace the fine adjust set screws. I have to use a flat head screwdriver.
Here is how I adjust the fine adjustment:
Lay stone on knife with angle cube.
Make the ball joint (joint part) square to the vice.
Adjust fine screw as needed. (make sure the ball joint does’t turn)
Make sure the stone does not move.
Tighten set screw.
The point of all this is if you lay the stone/rod down before tightening the set screw, the ball joint can turn the adjustment screw. If you leave the hex key in the adjustment screw it is easy to see. This will change the angle very slightly. So I make sure to tighten it up before moving the rod.
Also I try to keep the fine adjust screw run it all the way then turn out as needed. This way I keep the maximum thread engagement possible.
Finally, check the main set screw often. My right one comes loose some during sharpening. Left is not a problem. I will plan on using some Blue loc tire, but haven’t done this yet.
I got my arm upgrade real early. I ordered them 6 weeks early and got some of the first batch.. just for a time reference. I have not chaged the fine adjustment set screws and they have caused no problem with damaging the threads. I would guess that the nylon would give more protection, but you can also just flatten the lock screw tips …which I did for all of the set screws, and use reasonable force when tightening them…and you should be fine. Bottom line, if you just don’t crank them done excessively, you will be fine.
I did put the “Purple” locktite on all of the set screws. The purple is a light hold “breakable” thread locker. The blue or the red are considered permanent. It will go a long way towards keeping everything where you set it. This adds just enough friction for my use.
I haven’t covered the ball joints. I do have two magnets on each joint. These gather much of the loose metal. I wipe the joints with alcohol after a few kinives and put a coat of Super lube, a synthetic oil, on them. If I could find a proper well fitting boot, I would probably use it. I haven’t found one. So far, the joints look brand new, even with magnification. You could likely do nothing and the joints will last many, many years. By that time, clay will likely have something even better for you to buy…
I need to find some Purple Loctite, it is harder to find than Blue
The WE arms do work out of the box.
I have some magnets too, covered in metal dust.
The gloves fingers also give me reassurance when using water stones I am keeping that part dry. Otherwise with magnets I didn’t see much get on them before I did the glove fingers.
Do use an angle cube. This is what makes the new arms really shine. If you don’t you are missing out on their advantages, at least being able to dial an angle in better than the cube can measure.
