I’m moving the sharpening stones along the knife in a manner to put down a scratch pattern that is for the most part perpendicular to the knife edge. On the flat or mostly horizontal portion of the blade, the perpendicular motion for the stones on the guide rods are almost straight up and down. As I move across the edge approaching the downward curved tip to move the stones perpendicular relative to the knife edge the rods will be angled away from me. At the tip end of the blade for the almost round curved knife tip, for a perpendicular scratch pattern, the stone motion and the guide rods are almost horizontal. There are times when my scratch pattern is still crossing perpendicular to the knife edge but the stone on the guide rod is crossing the edge at a different angle. As I’m doing this stone work I’m continuously walking the stone along the edge bevel to prevent too much stone work in any one place. This blends the sharpening effort and the scratch patterns evenly along the knife edge.
While I’m keeping my strokes mostly perpendicular to the knife edge portion that I’m working on, this doesn’t effect or change the bevel’s set angle. Whether your sharpening strokes are edge leading, edge trailing, scrubbing up and down, going side to side or even round and around, as long as the sharpening stones are held consistently in flat contact against the knive’s bevels, the set angles will remains the same. By sharpening a knife’s length in smaller portions I have more control to keep the stones flat on the bevels and my set angles uniform.
This method is what I’ve found works well for me. Other’s have different ways to attack it. Irrespective of the type of sharpening strokes you are using, (i.e., edge trailing, edge leading, or sweeping strokes), to try to keep that stroke continuous and uniform down and across the entire knife’s length, when you reach the downward curving tip your sharpening strokes will be going almost sideways across the tip bevel. By the time they reach the tip some users may run out of stone length to finish the sharpening stroke. They find themselves reversing or backing up the stone’s direction as they look for more stone to negotiate the tip. This situation can occur just the same whether starting the sharpening stroke at the tip or with the heel.
This is the same common issue W.E. users have when sharpening a relatively short bladed knife, like an EDC. The knife edge is short enough that it may be sharpened heel to tip in one continuous sharpening stroke. With the stroke approaching the tip end, they find themselves trying to figure out how to make that stroke work right, while it’s still in motion. As the knive’s shapes change at the tip, this continuous sharpening stroke doesn’t cross the tip bevel in the same way that sharpened the flatter portions well.
Think of it this way…like you’re running up stairs. You have a good rhythm going. All of a sudden you reach the third step from the top where the steps oddly change height, angle and pad depth. You’re caught flat footed trying to figure out your footing in the middle of your running motion. You sort of stumble trying to keep the rhythm you had going. It doesn’t matter even if you know the step change is coming. It still disrupts your momentum as you adapt to the change. The same sort of thing happens as the knife tip curves down at the end of your moving sharpening stroke. You’re left trying to figure it out, how to go across it, in mid-motion. It’s hard to sharpen the entire edge with a rhythmic continuous stroke when you meet the downward tip. The curve effects your strokes and your results. This is why I do it as a separate portion then blend them together.
Another common issue to consider at the same time is that which “tcmeyer” wrote about above. It’s a common occurrence to wrap the stones over and around the knife edge as you reach the end of your sharpening stroke. By following through as Tom suggested, you’re lifting the stones up and off the knife tip as you use a continuously moving sharpening stroke.
Some new W.E. users may stop the stone dead, smack in the middle of the tip, before the stone has passed clear off it. Other users tend to push the stones inward towards the blade’s center-line once the stones pass off the tip. That is the same direction of their applied stone pressure against the knife bevels. They can roll the stones over the sharpened tip bevel as the stones are rotated inward around the guide rods. By concentrating on keeping your stones in consistent flat contact with the bevels while using an off and away stroke direction in a continuously moving follow-through, rolling over the tip bevels can be avoided.
