I happen to have a Spyderco Sharpmaker, my favourite sharpening system until I got the Wicked Edge. My Sharpmaker came with two stones, which Spyderco calls “medium” and “fine”. As cbwx34 wrote, Spyderco hasn’t published any grit/ratings or micron sizes of these stones.
Here are the Spyderco stones next to the Micro Fine ceramics.
As you can see, the color of the coarse micro fine ceramics is exactly the same as that of the Spyderco medium stones and the color of the fine micro fine ceramics is the same as that of the Spyderco fine stones. Coorstek has probably used the same pigments to color the Spyderco stones as the Wicked Edge stones. To me the stones also feel very similar (smoothness, hardness).
I took a few pictures of each of these stones under my microscope. This is the Spyderco medium stone:
And this is the coarse Micro Fine ceramic:
Although they look similar, the difference between these pictures seems significant: also if I take pictures on different spots on the stones, the Micro Fine ceramics have more and larger grey areas.
This is the Spyderco fine stone:
And this is the fine Micro Fine ceramic:
Again, the difference between the pictures seems significant: the Spyderco stones have more white spots, all over the stones.
I don’t know what to conclude from these pictures, other than that both the Spyderco and the Wicked Edge stones have similar structures, probably because they have been manufactured using similar processes. Which is not too surprising, since they were both manufactured by the same manufacturer
But it would be interesting if somebody could take a microscope picture of the Spyderco ultra fine ceramics.
To show that not all ceramic stones have the same structure, here are microscope pictures of the 1200/1600 ceramic stones. These were made by a different manufacturer.
The 1200 stone:
The 1600 stone:
