Just got my WE and noticed that when I get the blade all tightened in the two clamps/jaws move around on the base. Is this normal?
No that is not normal. Please check that you have both screws that run up from the bottom thru the adjustment bar in correct and that they are tight. It should be rock solid after that.
Took it apart and got em tight and now it works. Thanks. ![]()
You’re welcome. Now have at it and enjoy you’re new sharpener.
