Yes! Angle slop in my beloved WEPS! Backlash! The dreaded bane of all things precision.
I was recently humming along with some routine sharpening and I had just changed stones when I happened to stop to check with my microscope, only to find that the finer stones were only touching the top one-third of the bevel I was working. I hadn’t moved anything, so I retrieved the previous stone and checked it with my AngleCube. Then I did the same with the finer stone. Noticing some variation in the readings, I farted around with it for a while and identified at least two sources of error. First, there is a noticeable slop in the stone block itself. Second, there is an equal amount of slop in the ball joints.
None of this would necessarily be a problem, but there is a situation in which the two sources are additive. This happens when the force you apply to the stone falls below the level of the edge, as opposed to applying it above the edge. Mid-stroke transitions between the two certainly can’t be good, and it happens nearly every stroke.
No, my balls are not worn out (yeah, snicker, snicker). They look like new, have done certainly less than 100 blades and don’t even have a layer of dust on them, much less be contaminated by loose diamond grit.
Could this problem have been haunting me in my efforts to reach knife edge nirvana? Is it haunting you?
I didn’t see this until I was going to a micro-fine ceramic. Does this mean it’s only a problem with finer grits? Or does it mean that a bevel that isn’t flat can’t really be polished by a very fine grit as easily as it should?
I thenceforth tried to keep my hands low on the blocks and tried not to go above the edge line, at which the blocks would tip ever-so-slightly to a higher angle. Fewer sharpening problems so far. I haven’t heard any angels singing about this revelation of another truth, but we’re hopeful that God is letting his foot off the cold throttle in Wisconsin.
I’ll try to quantify the slop in the ball joints. Meanwhile, by my fairly educated eyeball, I’d guess 15 to 20 thou.
Excessive slop in a block could be fixed by pressing in each end a short sleeve of tighter tolerance.
