Although I have a bunch of Emerson knives, I’ve never been a fan of chisel grinds. While they have certain advantages, they also have disadvantages that for me have always been an irritation. Even their “V” grinds are not true "V’ grinds in the conventional sense, having more in common with chisel grinds than the conventional “V” grinds others used.
After getting quite comfortable with the WE Field and sport, having sharpened over 100 knives now, I thought I would experiment a bit, and try some things on an Emerson.
The one I chose for a testbed is an Emerson Gentleman Jim. It’s a “V” grind blade, with a micro bevel of around 30 degrees on the front, and about 15 on the back. Effectively not much different than their chisel grind, just sharpened as a micro bevel.
I’ve been sharpening this knife as I would a full chisel grind; 30 degrees on the front, and once I’ve reached 1000 grit, I knock the burr off the back side with a 1000 grit stone at around 15-16 degrees, then strop.
It gives a great, very sharp and very durable edge, but it still cuts like a chisel which is not what I prefer. So…today was the day.
First, do I re-profile it as a symmetrical or asymmetrical edge? Again, advantages and disadvantages to both. I chose asymmetrical.
To avoid completely revising the front, I decided to stay at 30 degrees. I wanted a solid, sharp and most importantly durable edge. I figured setting the back to 18 degrees might be an expedient solution, and perhaps a workable one too, with a 48 degree inclusive edge.
I ran through the stones from 100 grit to 1000 grit, with 100 passes per side. At 1000 grit, I added an extra 50 strokes per side…for good luck?? I guess that’s as good a reason as any.
I then started to strop; 100 strokes per side 5 micron, 3.5 micron, 1 micron diamond spray, then plain leather.
I was left with a very nicely polished edge, but taking it off the WE, my “finger test” said “this isn’t very sharp…”
This is a clear demonstration that the long relied on “fingertip test” is not worth much. I always keep last years phone book for testing edges, as I’m sure many of you do. I cut out a couple of pages, fully expecting the knife would not cut well at all.
How wrong could I be? Turns out I was about as wrong as possible. This edge is FAR sharper than it has ever been. Effortless hair shaving, cutting 1/8 in. ribbons of phone book paper, sliicing paper thin slices from a ripe tomato…straight slices, not the angled ones that you get with a chisel edge.
I have a bunch of short lengths of rope and paracord, so I started push cutting paracord. I ent through about 3 feet of it, then tried the tomato again. the same thin slices from it were no problem.
I think this edge is going to be quite durable, and it looks great. I’ll keep everyone posted on how it stands up
