Is it possible to make diamond stones that are shallow curved along their length in order to handle convex edges?
On my browser the URL didn’t parse correctly, let’s see if this is more click-friendly for Alan:
But note his question was about diamond stones; and with all the forum posts I’ve read about folks who have become disenchanted with their ceramics I wonder the same thing.
Hi Folks,
I was not clear enough. I meant that the stones would actually be curved in a very slight C curve not cross sectionally (SP?) as the ceramics that you sent me the link for (I have a pair of these already). Sort of like the brackets that I used in this post.
Thanks again for your replies.
Ah, I see what you’re getting at. You’re thinking of having the plates with a slight radius across the length of the cutting surface to intentionally put a convex edge on the blade. I imagine that it would be possible, but given that you can get a convex edge by making several facets and then blending them with strops without any extra tools, I don’t know if there would be much of a market for that idea.
These curved ceramics are of a much coarser grit as compared to the flat polishing micro-fine and ultra-fine ceramics that have a very long break-in period before you realize their benefits. The coarser curved ceramics did seem to work well for me right out-of-the-box. They exhibited a scratched pattern very similar to my comparable grit whetstones.
Plus, we’re working on something else right now to address convex edges in a really neat way. It’s still very much under development, but the proof of concept works great.
[quote quote=46282]
but given that you can get a convex edge by making several facets and then blending them with strops without any extra tools, I don’t know if there would be much of a market for that idea.Plus, we’re working on something else right now to address convex edges in a really neat way. It’s still very much under development, but the proof of concept works great.[/quote]
Keep us posted when you’re ready to break the news!
I’d love some detailed instructions/guidance on this. Does this entail rotating the stones from the plane of the blade?
[quote quote=46289]
…you can get a convex edge by making several facets and then blending them with strops..I’d love some detailed instructions/guidance on this. Does this entail rotating the stones from the plane of the blade?[/quote]
The process has been described several times on the forum and the knowledge base has good article on the topic as well. Here’s a recent thread on convex edges.
I thought KME has a curved rod specifically for convex edge sharpening. Clay, is this the route your design team thinking or something even more elegant?
The curved stone face (or curved rods) seems like a really interesting approach, but I wonder how you’d actually make it work. For instance, if the stones had a concave face and if you used diagonal down-strokes from tip to heel, the tip end of the edge would have a lower angle than the heel end. Switching to heel-to-tip diagonal strokes would theoretically result in two bevel facets at each end of the blade, with a section in the middle which would have a single more-or-less average facet angle. To achieve a uniform convex profile, you’d have to hone every point along the edge with every point along the face of the stone. Not unworkable, but I think it would demand quite a bit of focus and repeated inspections on the part of the user.
What do you think guys? Am I over-analyzing this?
The videos I posted of the two convex edges were a bit disappointing in terms of quality, but I had hoped for some commentary so that we could discuss other options and methods. Also, I didn’t make a big deal out of it, but by making a number of smaller angle incremental changes, the facets seem to blend together beautifully, making the use of strops unnecessary.
The blended bevel reminds me of digital audio, when you have enough frequency sampling points it begins to result in a near analog recording…
Ive always looked at digital/analog as particle/wave duality.
There is a (conceptually) simple solution to this: make a plate with a subtle undulating ripple along its long axis. This will give a continuously changing angle that combined with moderately different strokes should produce a convex edge in a nicely controlled range.
Rough calculation indicates that with one ripple (up/down) per inch you only need about 0.55mm peak-to-trough to give 10° of variation.
I think curved stones would not duplicate the consistent WEPPS bevels. The math (Anthony Yan’s) would be overly complex and full of approximations especially over curved sections.
I’m swinging to the side where I think it might be technically workable, but probably not practical. If I’m making the right assumptions, each point on the face of the curved stones would contact a different point of the bevel. To produce a continuous convex bevel, you’d have to use up/down strokes at every point along the edge, even at the tip. Add to that needing to make the same number of strokes at every point along the bevel. Then do that with every grit. Ouch.
This may be heresy but I use a Ken Onion Worksharp w/ grinder attachment for my convex blades. Personally - mine are all Bark River fixed blades and I can get a very useable and sharp edge with this setup. I use my Wicked Edge on my folders and kitchen knives. Don’t judge! LOL
Howard: Nothing wrong with using the WorkSharp or any of its ilk for their intended purpose. If I get a batch of knives to sharpen for a friend, the lesser-quality knifes are going to get my “buffing wheel quickie” job. If my time was more limited (I’m 12 years retired and don’t charge anybody for my work), I’d raise the standard for what’s a lesser quality knife. As it is, I try to use my WEPS for those knives deserving the extra time and effort. It gives me a sense of purpose and accomplishment that I don’t get anywhere else in less than an hour. When I return a knife to its owner, I know that he can’t get a more perfect job anywhere else. Note that I didn’t say “sharper.” Polished convex edges can be extremely sharp, but they can also have defects.
If you like, check out a number of the videos on Youtube, by Max the Knife and Curry Custom Cutlery. They both offer sharpening service as a source of income. Both gentlemen belong to the forum here and both use belt systems for most jobs. Max the Knife is tuffy braithwaite on this forum. You can see his youtube video page here.
Wait til you guys see what we have planned! It’s still in development, but I am really excited about getting it completed.
