When I first saw Tom’s microscope photographs of the edge of a knife after stropping with the 14 micron and 10 micron diamond pastes I was baffled. I was it again when I was able to repeat this myself. Even though the edge got very smooth and sharp, there were only tiny scratches caused by the pastes. How could pastes that were so little abrasive create such smooth edges, both on balsa and on leather?
I did some additional experiments and a bit of thinking. I think I now know why it was so difficult for me to comprehend how the diamond pastes work: I was trying to explain what I saw through the microscope in terms of assumptions I held about why stropping with the diamond compounds worked:
[ul]
[li]Leather has a stiction that causes it to burnish the edge, i.e. smear out metal over a larger area that causes scratches to become less wide and less deep or sometimes even to disappear.[/li]
[li]The diamond pastes are abrasive because they remove metal by making lots of scratches with a width and a depth of their specified micron size (or a little lower, since only a part of every diamond particle would touch the edge).[/li]
[li]The diamond pastes work on leather due to the dual effects of burnishing and abrasion.[/li]
[li]The diamond pastes work on balsa due to abrasion.[/li]
[/ul]
Tom had already shown that the second assumption was likely not true. It dawned on me when I saw with my own eyes that the first assumption was not true either. The additional experiments and thinking showed that all four assumptions are wrong!
my blogYet these pastes do work. So I tried to come up with an alternative explanation. You can read it in full on . But in short I think the following is happening:
[ul]
[li]Both the balsa and the leather strops are hardly abrasive by themselves. They do not cause much burnishing by themselves either.[/li]
[li]The strops become effective when loaded with the diamond pastes.[/li]
[li]The diamond pastes cause a lot of burnishing, but hardly any abrasion.[/li]
[/ul]
It is the pastes that do the work, not the strops. And these pastes are hardly abrasive, but have a strong burnishing power.
