Interesting experiments again, Clay!
[quote quote=“wickededge” post=2461]Slight tangent here - polishing tapes… I decided to retest the polishing tapes, starting from a polished bevel and counting strokes, so here goes, working backwards from 1 micron polish:
510x - 7000 grit polishing tapes after 1 micron polish - 100 passes
510x - 3000 grit polishing tapes after 7000 grit tapes - 100 passes
These look better than yesterday’s results but not overwhelming.[/quote]
Why do you think they are not overwhelmingly better? I clearly see scratches now that (I hope) are from the polishing tapes. They are also quite evenly spaced, creating a nice pattern almost like what a stone would do.
By the way, with current knowledge (it changes per day
) I think this it the way to test the very low micron size compounds/tapes/stones: first burnish the edge until it is very smooth (e.g. using the 1 micron paste, but I wouldn’t be surprised if the 14 micron paste worked as well
) and then do strokes with the fine stuff.
I think we should be careful in drawing such conclusions too early. In one post Clay noted that the 1 micron compound had by far the most stiction. That would imply that 300 strokes with the 1 micron paste should produce more burnishing than 300 strokes (in total) with the 10-3.5-1 micron pastes. But in fact the surface of the edge after the latter progression looks smoother.
I had similar results: sometimes a particular compound seemed to cause more burnishing than another compound, whereas in different circumstances the results were exactly the opposite. I think this might very well be the result of the way in which the strops were seasoned (and the amount of paste applied).
Are you sure that hardness isn’t a typo, Clay? But good to see the burnishing works just as good on harder steels!
[quote quote=“wickededge” post=2469]Next I decided to throw in a little side experiment - I sprayed some Hand American, 1 micron diamond spray on my already pasted 1 micron strops - big difference here, though not totally surprising:
510x - 1µ diamond and leather strops after 3.5µ diamond and leather strops - 100 passes
There are clearly a LOT more diamonds than when I was using the strops with just the paste.[/quote]
I am not quite sure what I see here. I I do see scratches, but not as many or as regular as those that would be caused by a 1 micron stone. Is that correct, Clay? If you’d increase the amount of spray applied, would the number of scratches increase and a more regular pattern appear?
