2200/3000 Diamond stones
Hello fellas. I was pondering the idea of purchasing the new 2200/3000 diamond stones. I have 100-1000 diamond stones, 1200/1600 ceramics, 2000/3000 sandpaper taped on glass platens, 3M lapping film 5, 3, 1, .3 micron laid on glass platens and to finish I have 5, 3.5, 1, .5 micron leather strops. Ive searched the forum and couldn’t find a definitive answer. My question is where does the 2200/3000 fit in? After the ceramics? After 1000 diamond then drop back to the 1200/1600 ceramics because of the abrasive/ substrate level? Thanks guys!
Justin, the tendency I see is that sharpeners try to do is lump all the different mediums together in one lone progression. They want to use everyone of their stones to sharpen and then polish the knife. The problem is that the different medium’s grits are often classified and rated by different scales so they don’t necessarily compare and fit together in a nice neat easy package. This is illustrated in this “Grand Unified Grit Comparison Chart”. It tries to give us a way to approximate or extrapolate the different mediums to place them in that more logical order that we seek. Here is “Wicked Edge’s Grit Comparison Chart”. It has not been updated, yet, to include the new 2200 and 3000 grit diamond stones.
Recently Clay attempted to address this issue in the Wicked Edges “Knowledge Base” with the article “Sharpening Grit Progression for all Wicked Edge Abrasives”. Maybe between the three links you’ll have the tools to make the decision you’re looking to make.
I think you need to decide what edge you are seeking and use this to limit which mediums and which progression you choose. For instance a mirrored polished edge, a durable edge, and a very sharp edge may all be achieved with a different stone progression. Clay’s article suggests some different progressions to follow to give you those specific results you seek.
I haven’t yet broken-in my 2200/3000-grit stones, so I can’t testify that my progression is correct, but if it works out, here’s my plan:
I have my stones rearranged to make things a little more regular. I have put my 100-grit stones on the practice squad, so my first pair are 200/400. Next is 600/800, then 1000/1500. I have replaced my 6-micron film with the 2200/3000-grit stones. I’m expecting (hoping) that the 3000-grit scratch pattern will more or less match the 6-micron film when it’s fully broken-in. If I wish to go higher in the degree of polish, I’ll resume with the 3/1.5 micron films. Next would be the 1.0/0.5 micron film or the same grits in strop compounds.
Matching the scratch patterns between the 3000-grit diamond and the 6-micron diamond film is more expected than hoped-for. The width of the scratches seems to be about the same under the microscope, but the overall appearance is much rougher - largely because it’s not yet broken-in. At these grits, the differences between broken-in and not broken-in are huge. I get a decent polish with my 1500-grit stones, but the 3000s are nowhere near that level of polish.
At some point not too long after WE started selling glass stones and diamond film, Clay observed that he could jump from 1000 directly to the 6 micron film. Or was it from the 1500s? I have always held that a step up in grit should be 1.5 to 2.0 times the previous grit. Such transitions would require only a nominal amount of effort for each step. If the 6-micron film is in fact the equivalent of 3000 grit stones, then Clay’s jump from 1500 to 6-micron was a 2.0-to-one transition, and by my standards, apparently reasonable. A higher jump (from 1000 to 6-micron) would just require a bit more effort. The 2200/3000-grit stones fill in perfectly for users who have a new set going up to 1000-grit. No ceramics, no film/glass to deal with. An all-diamond team on steel plates also benefit in the use of magnetic angle cubes.
What’s really nice about film is that there is absolutely no break-in period. What’s not so nice is that they are far more susceptible to contamination.
Unfortunately, I’m not doing much work at the knife sharpener this year. I’m bogged down in several other household, shop and cabinetmaking projects I have promised for a long time. Alas, this means I won’t get my new stones completely broken-in for several months.
What do you mean by 1.5- 2.0 times the previous grit? The reason I want to get the 2200/3000 diamonds is to replace the 2000 and 3000 sandpaper Im using since it doesnt last long and takes time swap out and replace. I would like to just grab stones and go. I also like the fact I would be able to continue with the diamond family before I hit the softer mediums. When I hit the 1200/1600 ceramics is when I start to see the effect of polishing and then work with lapping films and strops. I would say half the time Im after a mirror polish and the other half I stop at 1000 diamonds for a toothy working edge. Is it even worth it to add the 2200/3000 diamonds into my progression or should I stick to the progression I have?
Like Tom’s, my 2200/3000 grits aren’t broken in yet. If they come around, when they are finally broken in, and behave as well as the original 1500 grit diamond stones do, then I look forward to what they’ll bring to an all diamond stone progression.
Nobody can tell you whether the investment is worth it to you, Justin. Only you know exactly what you’re looking for.
[quote quote=51697]
What do you mean by 1.5- 2.0 times the previous grit? The reason I want to get the 2200/3000 diamonds is to replace the 2000 and 3000 sandpaper Im using since it doesnt last long and takes time swap out and replace. I would like to just grab stones and go. I also like the fact I would be able to continue with the diamond family before I hit the softer mediums. When I hit the 1200/1600 ceramics is when I start to see the effect of polishing and then work with lapping films and strops. I would say half the time Im after a mirror polish and the other half I stop at 1000 diamonds for a toothy working edge. Is it even worth it to add the 2200/3000 diamonds into my progression or should I stick to the progression I have?[/quote]
The 1.5 to 2 times the previous grit refers to the grit numbers themselves. If you’ve just finished with the 1000-grit stones, the next in progression would be somewhere between 1500 and 2000-grit, although, it’s not a hard and fast rule. If going from 100-grit t0 3000-grit seems to work for you, that’s just fine. The reason is solely to make the most progress with the least amount of wear on any one set of stones.
Your desire to “grab the stones and go” is exactly why I (as well as Marc, it seems) would like to get to an all-diamond progression. If the 2200/3000-grit stones turn out anywhere near as nicely as the 1500-s did, I’ll be there.
Given you have now had a good 6 weeks since the last post and hopefully some knife progressions performed.
How are these stones performing?
How have you adjusted your progression post 3000 grit?
i am in the process of breaking mine in, but am starting to see results for which I bought them.
i have yet to amend my progression cycle post these stones and wondered about yours
That’s a really good question, and I’ll be eager to hear a response from WE. I use a “mesh”/“micron” chart, which is somewhat different from grit ratings. Mesh refers to the opening size of a screen through which the particles would be sifted and sorted. It is very nearly the inverse of the micron size. Theoretically, a 1 micron particle would pass through a 25,400 mesh screen, as there are 25,400 microns in an inch. Advanced Abrasives’ chart shows 2200 and 3000 mesh as being approximately 8 and 6 microns respectively. Based on my personal experience, that’s pretty close to grit ratings
Welcome to the W.E. Forum Patrick Hunziker!
I my guessing your curious of the grit particle size on the new 2200/3000 grit diamond stones to help you to figure how to use and incorporate your other Wicked Edge stones and sharpening mediums together in your sharpening progression…from coarsest to finest.
Here is the link to an article from the Wicked Edge Knowledge base addressing this sharpening progression issue with suggested progressions.
Patrick, the grit size and size comparisons described for W.E. stones were originally made by visually observing the scratch depth, width and space between those scratches with a high powered microscope with distance measuring capabilities. The sizes as described are comparitive measurements done from grit to grit. How they relate to the visual size of scratches from other known size particles scratches.
Clay and W.E. have not done these visually observed comparative studies yet to determine these observed particle sizes. The only way we have to determine the physical grit size is by interpolation, like you did, to place them how you believe they’d logically fit into the existing grit comparison charts using grit numbers to rank or position them.
So yes, the information has not been released yet.
I had the 2200/3000 stones and sold them in favor of keeping my 1500/2200 stones and using DLFs 6 and 3 micron instead. I am happy with the decision.
We’re waiting to finish our study with Los Alamos National Labs before publishing any grit sizes since we’re probably moving to a new classification system.
Gee, I’ve never heard anyone complain about the gap from 200 to 400. And I’ve never wondered about a 300-grit option, much less thought I needed one.
I don’t see redundancy in the option to buy 2200/3000-grit stones. I see them as a sensible option for buyers who choose not to buy the 1500/glass w/ film stones, but who might want the newly-available 3000-grit stones, but need something to fill the gap.
Perhaps a 1500/3000-grit set might be attractive to some of us, but most of those users already have the 1500’s and wouldn’t want to pay for a grit they already had. I, for one, don’t know that the 2200-grit isn’t a better fit than the 1500’s. Would you consider 1500/3000’s as adding to the redundancy?
Perhaps I am missing something, but the statement below appears a bit overloaded with something…not sure what.
I guess I’m a bit of a simpleton…I purchased diamond stones that progress in reasonable grit, then asked Kyle about which DLFs to start with after 1500 grit and got an answer, then went on my way. No muss, no fuss. If I wanted to go further, I could get into nano cloth, diamond sprays and the what not, but honestly, I have no need to go further myself, and even know from reputable guys sharpening knives for a living are not going beyond 1 micron for mirror finishes.
Of course, it’s your choice to dive deep into all this, but honestly, be careful and not treat it like lives are on the line or something like that.
Seems we need to relax a bit here.
Perhaps; however, there are ways to ask and there are ways not to ask. I would have asked differently. Keep in mind that the grit structure, substrate layout, suggested progressions are through a specific system design that doesn’t address every possible combination of other options. Saying someone doesn’t know what they are selling is a major charge and you need a lot of evidence, especially from someone like Clay whose reputation is impeccable for dealing with customers and taking feedback seriously, before leveling such a potential invective.
From what I have observed, the 2200 / 3000 fits really well after the 1500 grit diamond stone and before the 1.4 / 0.6 micron ceramics. If you dig back in the forum archive you will find a thread around the time that the 1500 stone was introduced where Clay shared several microscope images of scratch patterns left by the 1500 stone as well as the various lapping films. In this thread Clay stated in relation to the scratches left by the 1500 grit stone that, “Most of the widest scratches measured between 2.5µ and 3.5µ from ridge to ridge.”
New 1500 Stone
In another old thread Clay shared some microscope images of the scratch patterns left by the ceramic stones. The 1600 ceramic yielded scratches that were slightly finer than those of the 1500 stone. See post 31960 on page 3 of the thread below where Clay shows that the 1600 grit ceramic scratches range between 2.6 micron and 3.3 micron in width.
Strops or Stones?
Based on this evidence, I suspect that the 2200 / 3000 will fit very well after your 1200 / 1600 stones. I cannot say for certain whether or not you will need the 5 micron or 3 micron lapping film in your progression. I like to overlap my grit ratings when changing from one type of sharpening medium to another.
I have done some knifes …1000 - 1500 - 2200 - 3000 - 3 micron lapping film. No complaints whatsoever.
Bandaid’s question/assertion may have been direct, gruff and undiplomatic but I don’t think it’s unreasonable to expect the specifications (i.e., grit particle size) of a product being marketed and sold is a known commodity, that can be shared. Afterall how to you rate the grits in order to name them without this information. Obviously W.E. and Clay had this information to make naming these new diamond stones possible. This information was asked for in this thread, by several posters.
Many of us prefer to determine our own sharpening, polishing and stropping progressions on our own basis on published specifications. For these newly marketed grits their were none. All we were provided with was a name without the basis for the naming. The stones seem to work well used in this order they were named. I can’t disagree with this.
I can state that I owned two sets of the originally introduced 1500 grit stones, from 2016, that were documented as Organic referenced above. My experience using my two sets of the newly released stone this past year, 2019, that they don’t behave similarly. I cannot state unequivocally that these newly released 1500 grit stones differ from the originally released 1500 stones from 2016. I have no specifications for documentation.
I can say based on my experience that the two era or version 1500 grit stones behave differently and for me yield different results. I use a USB microscope to visually inspect and photograph my sharpening sessions for all knives. The scratch patterns appear to me to differ. The new stones do work well. I cannot complain. They are not as fine as the first set of 1500 grit stones I still have and use. The new 1500 grit stones, after being well broken in, still do not yield anywhere near the polished effect I saw with my first 1500 grit set. I can simply state they appear to be different stones although named, similarly.
I’m concerned what will be the results if after the Los Alamos testing that the grit naming procedure is needed to be changed to a new separate chart. What if it determines that the 1500, 2200, and 3000 grit nomenclature are all wrong based on the particle size studies, investigation and determination. This certainly would reflect, in my mind that the however, roughly stated assertion by bandaid, is possibly indeed correct. It certainly would suggest as asserted that the products as marketed and sold are an unknown commodity.
I want to add, to make it very clear, I do not assert that these products or any products introduced, marketed and sold by Wicked Edge, Clay and his company are not top quality and fully functional products. I enjoy using them all. I just suggest the documentation as requested could be more forthcoming.
Doesn’t look like we are relaxing much…
I don’t think it wise to make enemies here.
