Wicked Edge custom rods/paddles
Recent Forums Main Forum Sharpener and Accessory Maintenance MODS Wicked Edge custom rods/paddles
Viewing 15 posts - 1 through 15 (of 27 total)
  • #29813
    Can’t wait to get this up and running!
    #29816
    Wow, that’s impressive! And definitely heavy-duty. I also like your ideas for new paddles.
    Hadn’t you made your own vise, too? By now then you’ve almost made your own WEPS 🙂 .
    #29817
    Alan
    • Topics: 16
    Nice job!  Thanks for posting.
    Alan
    #29819
    Pinkfloyd
    • Topics: 22
    Nice! If you go with a magnet you would be able swap out stones with just a few blanks.
    #29820
    <p style=”text-align: center;”></p>
    <p style=”text-align: center;”>Thanks guys! Any ideas on what material to use for the blocks? I think Tom and I were discussing ABS a while back…</p>
    Wow, that’s impressive! And definitely heavy-duty. I also like your ideas for new paddles. Hadn’t you made your own vise, too? By now then you’ve almost made your own WEPS :) .
    </p>
    <p style=”text-align: center;”>Yeah ?ways tweaking for the next level of performance!</p>
    </p>
    <p style=”text-align: center;”>Yeah I’m thinking I will still just have paddles with the current design – 2 grits per paddle. But I go through stones about 2 times a year or so it would save time just to pop off the used stone and stick the new one on with no adhesive issues hehe.
    </p>
    #29821
    Clay mentioned to me once that WE was considering a design with a single set of precision paddles with interchangeable stones.  Maybe they’ll come around to selling the platens separately.  That would surely reduce the cost of replacing stones.
    #29822
    Geocyclist
    • Topics: 25
    Thanks Josh, great video.  For something like that a video is much better than just photos.
    #29823
    In that case you don’t want any ideas from me… I was thinking: plastic 🙂
    #29825
    How do you guys say “Thank you”? Do I miss something obvious or am I forbidden to say this?
    #29826
    The mod should know this?! ;p jk. Next to the “quote” and “reply” buttons is a “thanks” button…see it?
    #29828
    Ah, it’s there! It’s just that in my case it is in between 8 other buttons. (Still easy to accidentally press “Trash”. But now there’s a safeguard: you have to press it twice.)
    #31240
    By way of an update!
    #31241
    CliffCurry
    • Topics: 42
    How stoked are you right about now?  Thanks for sharing the jig design.  That bore looked spot on when you showed the end view!
    I had a local wood worker make me some blank paddles out of hard wood.  I gave him the dimensions and bore diameter and impressed on him how important having the hole centered was.  He gave me 4 sets of paddles that were unusable.  Looks like he tried to drill it free hand while holding in the other.  Booo
    #31242
    Anonymous
    Inactive
    • Topics: 14
    If money was not an object and had access to a machine shop, I would use Delrin… easily machined and you would not need to add additional machining for bushings.
    Polyoxymethylene, also known as acetal, polyacetal and polyformaldehyde, is an engineering thermoplastic used in precision parts requiring high stiffness, low friction and excellent dimensional stability. As with many other synthetic polymers, it is produced by different chemical firms with slightly different formulas and sold variously by such names as Delrin, Celcon, Ramtal, Duracon, Kepital and Hostaform
    #31243
    Hi Josh:  Lookin’ good!  Using shims to compensate for differences in block dimensions is what drove me to using the VSTA’s, but your setup is clearly better for finding true centers.  Maybe your buddy can come up with a jig to perfect the block dimensions too – then you wouldn’t have to change shims.
    I think longer bushings would help to keep your bores more accurate – you can buy longer drill bits from McMaster so you wouldn’t have to drill from both ends.  Certainly, the 0.375 bit will drill truer than the 0.250, making that more practical.  I couldn’t get the 0.250″ to stay on true center for the full length.
