Why water stones?
Viewing 15 posts - 31 through 45 (of 120 total)
  • #7107
    Scott
    • Topics: 27
    Thanks Phil,
    Very informative and helpful. I appreciate your sharing this info, even though it may wind up costing me a bunch more now. I see where the Chosera stones are now listed on the website among the top selling accessories.
    By the way, you mention that you go back to the 2/3 K Chosera Stones, ( presume before finishing them with the 5K/10K C Stones.
    Could you do just as well after going through the diamond progression and then the ceramic progression with the added strokes and then to the 5/10 K C Stones or even just the 10 K C Stone since the micro fine ceramic is pretty close to what the 10 K grit is supposed to be? Or do you really need to go back to the 3 K C Stone and then move forward from there. Also, I guess if you do that why go all the way through the diamonds to ceramics and then to the Choseras. Why not just go from 1000 diamond to 3/4 K Chosera then 5/10 K?
    Love the feedback available here. Great job.
    #7112
    Phil Pasteur
    • Topics: 10
    Thanks Phil,
    Interesting that you ask. “usually” after going throught the diamond progression I .. “go back” the the 400 Choseras. They are listed as being much more coarse than the 600 diamonds. Maybe they are, but they “seem” to remove a good bit of tyhe diamond scratches.. after the 1000 grit Diamonds… and brighten up the edge considerably.
    I then go to the 600, then 800 then 1000 choseras.. The 1000 are still more coarse then the 1000 diamonds.
    After the 1K Choseras we are getting a real nice reflective finish. After the 2K/3K (Tom says this is dependant on the particular blade… being OCD I use them both) It is definitely more reflective at that point, than I got going through the last three knives ..in different steels, than the result using the 4 stones progression with the ceramics from WEPS after the diamonds. The Ceramics “cut” the Choseras.. cut AND polish.
    I think you could get there with the 5K/10K Choseras after the ceramics.. It would just take lots more strokes…
    As Curtis said, you could get there with strops and the WEPS pastes… and maybe we could… But, again, with lots more strokes.
    More in a bit.. need to walk the dogs!
    #7115
    Lukas Pop
    • Topics: 10
    What is the benefit of using 100-1000 diamond progression first? I heard that 400 Choseras work very fast, so why you don’t start with them?
    #7118
    Mikedoh
    ?? Cutting down on stone wear maybe?
    #7120
    Phil Pasteur
    • Topics: 10
    Speed. The diamonds cut much faster. By their nature, they tend to cut deeper as well. These (relatively) big honkin troughs are what I want to get out with the Choseras. While the 400 Choseras are pretty fast, they can’t touch the 100/200 diamonds for speed.
    I think I have seen some Naniwa SuperStones in 120 and 220. These are something I would like to try some day. They could replace the diamonds for all but major repairs I think.
    #7123
    Phil Pasteur
    • Topics: 10
    So…. after fnishing up the Damascus mule I deciced to go back to the other Mule with the BCTS-B75P steel and see what some additional stropping would do for it. First, this steel is very close in chemical make up to BG 42 which was used for awhile in custom knives. The biggest use for BG42 was in aerospace for making ball bearings. It can be left very hard, I believe up to Rc 66 or better and polishes very well. The BCTS-B75P is Carpenter Steel’s powder metalurgy version of the BG42. In the Mule it is supposedly hardened to around Rc 63. It should polish even better than the BG42 as the powder technology is designed to produce a finer grain with more uniform distribution of its carbides and the Vanadium which differentiates it.
    If you remember from a previous post I had reprofiled this blade with the 100/200 diamonds and worked on it through the 1000 grit diamonds followed by the four grades of WEPS Ceramics. I then did a few strokes per side with 6 micron DMT paste on leather. The finish, while somewhat reflective, still had a lot of visible very fine scratches. Keep in mind that I went to about 200 strokes with each set of the ceramics and alternated every 50 with edge leading and edge trailing strokes. I really wanted to get results that would allow me to use this as my standard progression. It is fairly fast and there is little fiddling with angles. I think for a utility blade or a customer who did not want to pay for the ultimate polish, it could fit that bill nicely.
    This time I wanted to follow-up on something that Curtis said. In essence I think I heard that he thought that the Choseras could be replaced by the WEPS pastes to get to the same place. I wanted to see how that would work for me. So I went back to the 14/10 WEPS paste on leather. I hoped to start at this level to get rid of some of the Ceramic scrathces relatively quickly, and I did. I used about 200 strokes at each grit. BTW, I changed my angle from 18 degrees on the main bevel to 17.25 degrees. I then went to 6/3 micron, then 1/0.5 on leather, then 0.125 CBN and 0.1 Diamond on Kangaroo then 0.050 and 0.025 micron dimond on NanoCloth for, again, about 200 strokes per side, per grit.
    Bottom line, I had a very sharp, litterally hair whittling edge and a quite shiny bevel. I still had far more fine scratches visible than on the blade done with the Chosera progression to 10K, the 12K superstone, and then from 1 micron down to 0.025 micron strops as above… and the edge is just not quite as bright. Of course this is an entielr different steel than the VG10. I have a second mule in the BCTS-B75P, one day I will have to go back and do it the way I did the VG10 so I can directly compare.
    I will see If I can get some pics that will capture what I am talking about… it was 11:30 by the time I finished up last night…and I get up before 5 AM. The pics will have to wait 🙂
    I hope this does soembody some good!
    #7128
    Ken Buzbee
    • Topics: 14
    It definitely does, Phil. Very good reading. Thanks for posting it!
    Ken
    #7138
    Scott
    • Topics: 27
    Thanks very much for taking time to experiment and report your observations. It is very helpful and appreciated. It certainly shortens the learning curve and at least for some may save money so they don’t have to buy stones or accessories they won’t need or allows some to add stones that they may not have been aware of or get results that otherwise might have been unobtainable.
    This goes to all who take the time to experiment and share. Or just share their knowledge or experience.
    #7150
    Geocyclist
    • Topics: 25
    Phil,
    Again, great write up and lots of good info. I can’t wait to get my Chosera’s.
    #7151
    Scott
    • Topics: 27
    Andrew,
    Which Chosera’s did you buy?
    #7153
    Geocyclist
    • Topics: 25
    I jumped in all the way and got them all. My initial thought was 800/1000 and 2k/3k were enough. Based on a lot of feedback I decided to get the 400/600 to back that course to get the diamond scratches out. After that I decided might as well get the 5k/10k too. At least those should save some stropping time. Probably still a good decision, may not use 10k on every knife but probably will use 5k all the time.
    #7157
    Phil Pasteur
    • Topics: 10
    I will be very interested to hear what you think…
    It took me about 8 to 10 months to make myself spring for the whole set. I started with the 400/600 and the 800/1000. I had nothing beyond the 1000 diamonds. I think that you will be very impressed with the edge after the 1000 Chosera. I often leave it at that …with a bit of stropping. A nice edge.
    A bit of tooth, but with a decent amount of reflectivity.
    #7160
    Scott
    • Topics: 27
    WOW! That is way cool.
    I will also be very interested in your experiences with them. I sure hope you will share what you learn. I really wanted to get some Chosera’s but could not pop for the full set since I am sooooooo heavily invested in my PP2 + several extra strops, and two extra sets of ceramics and the 50/80 stones. I was playing with the idea of getting just a set of 5k/10k Chosera’s to finish off my mirrored blades after the ceramics. So it will be very interesting to me to hear if you think you actually need to go through the whole Chosera progression or just use the 5k/ 10k after the ceramics to get a nice mirror. Anyway, enjoy and know that I am at least a little jealous.:unsure:
    #7186
    Geocyclist
    • Topics: 25
    I am interested to see the difference between a “bit of tooth” vs. very fine. I will have to post my findings. Before I pulled the trigger on these I read some as well about plain bench choseras. They have very good reputation among hand sharpeners as well.
    #7188
    Phil Pasteur
    • Topics: 10
    I read some as well about “plain bench chasers”. They have very good reputation among hand sharpeners as well.
    What is that? Not …hopefully not to show too vividly my ignorance… but I have not seen that term…
    Bench strop perhaps?
