LukasPop,
How many knives did it take to wear down your 100 grit to be finer than your 200? Thought I read somewhere that the diamonds would be to sharpen around 500 knives.
Hi TedS, I did about 25 reprofiles. If you don’t need to reprofile, the amount of work is much less. The edges after 100 grit look very well under microscope now, but the speed of reprofiling is reduced. I don’t know how long this state will persist. But it seems to me that diamonds are rounded only, not removed from the base, so I think they have much time ahead. I suppose finer grits to endure very long as you don’t use (you shouldn’t) pressure when refining the edge.[/quote]
Good news. I have washed my stones thoroughly with dishes cleaner and old toothbrush, and my 100s cuts much faster now
