WE66 or Generation 4 Pro?
Recent Forums Main Forum WE66 or Generation 4 Pro?
  • #59229
    Lee
    Hi guys,
    Ive wanted a wicked edge sharpener for as long as I can remember, and I think im about to bite the bullet and buy one, however I can’t decide between the WE66 or the Gen 4 Pro.
    I currently have a Worksharp Precision Adjust and it’s awful. The clamped blades move and wobble with little to no pressure, even during sharpening. I can set the bevel angle exact on side of the knife, flip it over and it is 1.5 degrees out. I hate it.
    I was initially thinking of getting the WE66, plus 100/200, 400/600, 800/1000, strop, the angle cube, and the angle guide. However, for pretty much the same price I can get the Gen 4 Pro with all of the stones I want minus the strop.
    Questions:
    1 – How accurate is the angle on each side of the Gen 4 Pro? My workshop being 1.5 degrees out from one side to the other has really hit a nerve. I like the fact that with the WE66 I can adjust each side individually, and using the angle cube, I can get both sides to the exact angle I want. Im concerned that there is some risk that the Gen 4 pro won’t be 100% the same each side. I know I can get the micro adjust version however I don’t have the budget for the additional cost.
    2 – with the cam lock vise, is there any wobble in the knife or is it held solid? Again, my workshop has caused trust issues lol.
    Thanks for the input.
    #59230
    Welcome to the W.E. Forum Lee.
    First, Micro-Angle adjusters are necessary in my experiences to allow you to precisely match bevels angles as applied by the knife maker. The G4P model without the micro-adjusters will not give you the selective predictable, precision control of all your angle settings.
    The WE66 and the Gen 4 Pr0 will allow for similar results with similar level of user experience. The two models are equally similar to use although the micr0-angle adjustment mechanisms differ from model to model. The Gen 4 Pro has separate gross angle and fine angle adjustment features. In the WE66, all adjustments are done with a single knurled knob.   The same precision, accuracy can be achieved just as easily with either model.
    The knife sharpening process or regimen and the sharpening and polishing mediums are the same for both of these models.
    The WE66 is a smaller more compact model that lends itself to portability. The larger Gen 4 Pro is more of a desktop model and heavier to carry.
    Here is a video I produced some time ago:
    https://www.facebook.com/share/g/1KKb6w86FQ/
    #59231
    Lee
    Thanks for the vid.
    Im starting to think it worth while to get one with micro adjustment as per your recommendation. I will likely go for the WE66.
    What do you think of how sturdy the knife is clamped in the vise?
    As mentioned, my wolfcraft sharpener doesnt clamp it very well and the knife moves a fair bit when sharpening. Even the weight of the stone is enough to push the bevel angle out considerable.
    #59232
    The Dual-Cam vise, included with the Gen 4 Pros and WE66s, clamps and holds very well for most knives. Since I sharpen mostly full-size chef’s knives, I do always work with a Stabil-Rizer Clamping System Accessory on all my WEPS setups. This is for added rigidity, and lateral or rotational stability.
    The Micro-angle adjusters allow you to utilize the full precision and accuracy the WEPS offers.  With the adjusters you can match the precise bevel angle(s) applied by the knife smith.
    My WE sharpeners are mounted on heavy bases to enhance user’s stability.
    Stabil-Rizers-SRG4P
    Stabil-Rizers-WE66
    #59240
    David N
    Lee, you expressed concern about your workshop being 1.5 degrees different from one side to the other. I’m not sure if you’re talking about the room you work in or some other type of sharpening system (Worksharp?). If you’re actually concerned about your workshop, that’s not going to make any difference. All that matters is the angle adjustments on the Wicked Edge relative to the clamp, which will be the same regardless of whether you’re on a precision leveled surface or the the side of a mountain slope.
    If you’re asking about how precise the angle adjustments are from side to side on the WE, I don’t know an exact number but I’m going to say it mostly comes down to play (slop) in the stones riding on the rods. Using the digital angle finder that came with the Low Angle Adapter kit from WE, I get 0.2 degrees of play. How much difference does that make in getting knives sharp? Not much as far as I can tell. Everything else on the WE feels rock solid. I got my WE Pro Gen 4 yesterday. I practiced on 3 knives I didn’t care about and then did one of our middle of the road kitchen knives (a 9″ chef’s knife). It came out sharp enough to shave.
    Regarding the precision adjustment feature, get it if any of these things are true…
    • you will be sharpening a lot of knives or have any sort of commercial use case
    • you have the money
    • you have expensive knives
    I also agonized over whether to spend the money on the precision adjustment. Now that I’ve got it, I’m glad I spent the extra money. I reprofiled the edge on one of our cheap kitchen knives because it was a degree or two off from the other side and it took much longer than just sharpening. What might have been an 8 – 10 minute sharpening session if I left the bevels as-is turned into nearly an hour. Huge waste of time for something that won’t make any noticeable difference. Also about 10x or more wear on the 100 grit stone than it would have been if I’d just left it. Anyway, all that to say, get the precision adjustment if you can. It makes it significantly easier. On the second kitchen knife I sharpened, I used the coarse adjustment to get get as close as possible to the existing angle and then used the fine adjust to match it exactly. Sharpening that knife was a breeze.
    #59241
    The precision and accuracy is there. It’s for you to utilize.  I see +/-0.03º with due diligence, effort and attention to details. It’s more work than is needed to achieve a very nicely sharpened knife.  The precision will allow you to go as far as you want to, to explore “how sharp is sharp”
    BTW: David N., Those diamond stones improve with break-in. Don’t fear you’re wasting them.
    #59245
    000Robert
    • Topics: 7
    I bought a set of 50/80 stones for reprofiling. I love them but you have to be careful with them – they can shred some steel. But they save your arms and your 100 grit stones, especially when reprofiling chisels. They are worth every penny.
