WE66 Obsidian set up
Recent Forums Main Forum WE66 Obsidian set up
  • #58365
    Shophand
    What I want is a riser and 1/4 jaw upgrade hopefully soon.:) But this is my Current set up 🙂
    • This topic was modified 2 years, 6 months ago by Shophand.
    #58369
    airscapes
    • Topics: 20
    With the riser I make, I suggest the 13″ rods and a set of stone stops.  The stops will prevent you going too high and coming down on the fresh bevel  or going too low on a taller knife.
    #58370
    Shophand
    I have a built in stone rod holder if thats what you mean. So you make a riser for the obsidian? I also plan on getting the 13″ rods too soon:)
    #58373
    airscapes
    • Topics: 20
    Yes I do.. can see it here https://knife.wickededgeusa.com/forums/topic/we60-66-new-accessories/
    #58374
    Shophand
    thats awesome ill have to get with you this week end and see if i can get one that will fit the cam vise 🙂
    #58375
    Pinkfloyd
    • Topics: 22
    Nice Setup!
    #58383
    Shophand
    So I added a another 1/2 base under the sharpener. I also got my high angle adapter and the 13″ rods in. These are the changes I have made. I am planning to get the 1/4 jaw upgrade as soon as it drops 🙂
    • This reply was modified 2 years, 6 months ago by Shophand.
    #58386
    airscapes
    • Topics: 20
    you may want to think about an angle cube if you don’t have one.  Once your bevel is more than 5/8″ above the vise,  the numbers on the device are no longer accurate.  I just didn’t see one in any of the photos so assume you do not have one.
    #58390
    Shophand
    Thanks Airscapes yes I have one. On a side note would it not be cool if the arms were digital.meaning you could see the angle on the sharpener.
    #58410
    Shophand
    If you are having trouble sharpening Daggers or other exotic blades this will let you sharpen anything even the smallest ones. The Tormek small knife adapter.
