Top quality cutting boards
Recent Forums Main Forum Off Topic Top quality cutting boards
  • #40232
    If you, like me, have a collection of nice Japanese kitchen knives (hard, tough, wear-resistant and of course beautiful), you probably like to cut your food well. The most important factor in this is, of course, your technique, but a good cutting board also definitely helps: https://wordpress.com/post/japaneseknifereviews.wordpress.com/2571
    #40236
    Mark, I think I made an error, although the address works for me. The address is https://japaneseknifereviews.wordpress.com/. Does this work?
    #40244
    Yes, that link works. What happened to my reply to your original post? It looks like you replied as me somehow and my original comment is gone.
    #40245
    Those are cool. I would be worried about getting scratches in those because they’re so beautiful to look at.
    #40246
    • Topics: 84
    Is the Psychedelic cutting board for cutting Psilocybin Mushrooms?
    #40247
    Perhaps it is also well suited for finely dicing peyote.
    #40248
    LOL about the mushrooms and the peyote.
    When I use them seriously, I usually put one of those $1 IKEA thin plastic cutting boards on them. Problem is, my knives are often so sharp I’ve destroyed three of those cutting boards already .
    Organic, I did nothing to your original post. Somebody else must have removed it (although that is definitely not policy here.) It seems that my second post, in which I posted the correct address (which you quoted in your – now – second post) is also gone.
    Anyway, the address is  https://japaneseknifereviews.wordpress.com/ to the blog and https://japaneseknifereviews.wordpress.com/2017/07/19/top-quality-cutting-boards/ directly to the post about cutting boards.
    #40255
    Doesn’t that nullify the advantage of using an end-grain cutting board?
    #40266
    They are all end-grain cutting boards. Is that what you mean?
    #40268
    As I understand it, the main reason to use an end grain cutting board is to give your knives a soft and resilient surface to cut on. If you cover that with a plastic mat, doesn’t that negate this desireable attribute?
    #40269
    That’s correct. But the IKEA plastic boards are also very soft and resilient (and thin). I didn’t cut them accidentally
    #40271
    • Topics: 84
    Sorry…. then you may as well use any wood board under the Ikea and not bother with the “Work of Art” boards because your negating the attributes of using end cut wood.
    #40275
    Sure. But my wood boards look very good and I only use the IKEA boards only occasionally.
