Thinning a knife
Recent Forums Main Forum Thinning a knife
  • #38442
    Pinkfloyd
    • Topics: 22
    Tried to search forum to find info on thinning a knife with the WEPS, search did not return any hits. I know some have posted info on this, so I’m asking for help. Friend gave me a never used custom knife that has a very small bevel, and wont cut very well. He used it to skin a Deer and it did not perform very well. I think it needs to be thinned, then maybe a nice 20 deg finished edge. I don’t have a belt sander, just my WEPS. Any help greatly appreciated. Attached is photo of edge but I don’t think its a very good pic.
    #38444
    Anonymous
    Inactive
    Just reprofile it to 20dps then sharpen it.  That would be the easy solution and can be done on weps
    #38445
    It’s hard to tell how thick the knife is from the picture, but I agree with SupraneGuru that you should try re-profiling the secondary bevel before you try regrinding the whole knife profile.
    As to your question about using the wicked edge to thin a blade, I don’t know if it can be done. I think the clamp will interfere with the stones ability to abrade the main bevel of the knife.
    #38447
    I agree, I would reprofile and call it a day… You don’t want to regrind it with anything but a belt sander imho.
    #38453
    If I wanted to thin a blade, I’d send it directly to Josh at RazorEdgeKnives (see the above post).  That said, I don’t think blade thickness will prevent a knife from successfully skinning a deer.  In fact, I think a very thin blade may be likely to slice into the hide accidentally.  I’ve been told that skinners may be best sharpened at 22-25 dps.  I did one a couple of years ago for a friend; I don’t recall the angles, but I polished a main bevel and ended with a 1000-grit microbevel.  He was happy with it.
    Could be maybe the edge was too polished?  As in no tooth?
    #38457
    Same idea here. Or even make it a multi-bevel (>2 bevels) or convex knife.
    #38459
    Pinkfloyd
    • Topics: 22
    Thanks Guys for your help. Sharpened at 22 deg, 200-1600 ceramics. Shaves hair and shreds paper. Had a brain fart when first looking at this knife, because of the very shallow angle. Included pics, but not very good
